Removing hoses on an ea81
3 replies to this topic
#1 subestyle18
subestyle18
    USMB is life!
  • 212 posts
  • Woodinville
Posted 20 June 2007 - 10:25 PM
I am looking to get rid of unessacary hoses from my ea81 with hydro heads. I have am running the weber so i have no need for emission components. I've seen a picture a while back from qman of a clean engine, but that was years ago.
thanks
#2 CHIM
CHIM
    I think i can break that.
  • 366 posts
  • Oregon
Posted 21 June 2007 - 01:23 PM
thanks
Start by looking at what you do need.
1.The vacuume advance that runs from your disty to the front of the weber.
2.The large hose that runs from the manifold to the break booster.
3.a smaller hose that runs from the manifold to the firewall on the passenger side (for the heater controls).
4. the switched hot wire for your choke (if it's electric).
If it's not one of those it can be removed.
I like to remove the intake so i can remove the hard lines under the intake, also i remove the egr valve and put a plate in it's place and use brass plugs to cap the egr pipe in the head.
Less is more, i like simple setups, easyer to work on.
~CHIM~
#3 hatchsub
hatchsub
    Currently Subaru-less :(
  • 2,714 posts
  • Guilford
Posted 21 June 2007 - 06:16 PM
~CHIM~
I agree removing the hard lines from the intake would make it look nicer but i was lazy when i did my weber swap. The only thing i cant understand is why everyone does away with the EGR valve? Doesnt it do way more good than harm with it lowering the cylinder tempertures? I left mine on since it was still in good working order.
#4 CHIM
CHIM
  • 366 posts
  • Oregon
Posted 22 June 2007 - 01:09 PM
Early EGR systems were relatively unsophisticated, utilizing manifold vacuum as the only input to an on/off EGR valve; reduced performance and/or drivability were common side-effects. However, modern systems utilizing electronic engine control computers. multiple control inputs, and servo-driven EGR valves typically improve performance/efficiency with no impact on drivability. In the past, a meaningful fraction of car owners disconnected their EGR systems. Some still do either because they know EGR reduces power output, causes a build-up in the intake manifold in diesel engines, or know that the environmental impact of EGR's outweigh the NOx emission reductions.
I also noticed an increase in performance, but only slightly.
~CHIM~
