82glsw Posted July 3, 2007 Share Posted July 3, 2007 I know there are several threads about torgue bind but i could find what i was looking for. Is there any specific type of auto tranny fluid that helps better then others. Quote Link to comment Share on other sites More sharing options...
nipper Posted July 3, 2007 Share Posted July 3, 2007 Clean fluid. Some add Lucas LSD additive which helps depending upon the cause of the TB. nipper Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted July 4, 2007 Share Posted July 4, 2007 Yes, the LSD limited slip differential additive can be something to try, and Subaru recommended it for certain vehicles at some point if there was binding. Beyond that, a good Dexron fluid should do the job. Some synthetic multi-purpose ATF's that are also suggested for Dexron apps may be more heavily friction modified. Quote Link to comment Share on other sites More sharing options...
82glsw Posted July 4, 2007 Author Share Posted July 4, 2007 How much additive should i add to the fluid Quote Link to comment Share on other sites More sharing options...
torxxx Posted July 8, 2007 Share Posted July 8, 2007 follow the instructions on the bottle Quote Link to comment Share on other sites More sharing options...
msmithmmx Posted July 8, 2007 Share Posted July 8, 2007 I purchased the additive from a dodge dealship. But I never used it, I had my tires rotated and balanced to fix the issue (Thanks Nipper) Quote Link to comment Share on other sites More sharing options...
82glsw Posted July 8, 2007 Author Share Posted July 8, 2007 Has anyone ever used royal purple automatic transmisson fluid Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted July 8, 2007 Share Posted July 8, 2007 The instructions on the bottle of the limited slip additive are going to be for its normal use in gear oil. I'm trying to find the TSB or wherever Subaru said to use the GM limited slip additive for binding. I haven't searched too much yet but someone on nasioc said "The info about limited-slip additive can be found in Nov. 1996 TIPS newsletter." I haven't tried royal purple. Have tried amsoil synthetic atf and mobil1 synthetic atf and those worked fine. The generic autozone atf seemed to work fine too. Quote Link to comment Share on other sites More sharing options...
