Questions on Strut/Coil
3 replies to this topic
#1 Guest_hocrest_*
Guest_hocrest_*
  • Guests
Posted 22 July 2003 - 09:35 PM
Does anybody know if there are any adverse effects to putting rear struts/coils from an outback onto my legacy. I'm not quite ready to go for mudrat's lift kit, but a little more height and maybe some larger wheels and tires would be nice at times.
Also is there a difference between sedan and wagon rear pieces. I checked a couple online sources and some seemed to have different selections for sedan and wagon, and some didn't show a difference.
#2 Guest_wrxsubaru_*
Guest_wrxsubaru_*
  • Guests
Posted 22 July 2003 - 09:47 PM
I dont think there would be any adverse afects, ecept a lifted rear end. I think there are diffrences between the sedan and the wagon springs because of the weight diffrences.
#3 Guest_Legacy777_*
Guest_Legacy777_*
  • Guests
Posted 23 July 2003 - 06:40 AM
You should be able to put outback stuff on your legacy. Make sure you get the whole assembly, struts, coils, etc.
Yes there is a difference in struts & springs for wagons & sedans. As mentioned the wagon is a little heavier and meant to haul stuff, so it's rear spring/strut combo is a little firmer.
#4 Guest_hocrest_*
Guest_hocrest_*
  • Guests
Posted 23 July 2003 - 09:09 AM
That may work out better, as my trunk and back seat are usually filled with oxygen tanks, and other equipment...
Thanks for the help:)
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
