fitting webber carb to ea71 motor question?
10 replies to this topic
#1 kiwi subbie
kiwi subbie
    Certified Subaru Nut
  • 932 posts
  • Christchurch, New Zealand
Posted 08 July 2007 - 04:29 AM
just wondering if an Dual throat down draught carb 32/36 DGAV
32mm primary,36mm secondary webber carb work on ea71 motor?
thanxs :burnout:
#2 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,184 posts
  • Central Iowa
Posted 08 July 2007 - 04:03 PM
thanxs :burnout:
yes, takes same adapter as the EA81.
#3 kiwi subbie
kiwi subbie
  • 932 posts
Posted 09 July 2007 - 01:07 AM
were bouts do ya get an adapter from? will i have to rejet it? coz its of an 2L cortina engine
thanxs :burnout:
#4 Jerry DeMoss
Jerry DeMoss
    Pushrods 'O' Fury
  • 2,408 posts
  • Colorado
Posted 09 July 2007 - 07:34 AM
Yes I think you would have to get it re-jetted since it came off of a different car. What size engine was in the car you pulled it from? Just thought if you got it from something with similar displacement you may have a good starting point.
As far as the adapter goes, alot of people order from redline. I have seen several adapters in Australia for sale on ebay. There is a good weber thread on here,should answer any other questions you might come across. Good luck.
#5 mcbrat
mcbrat
  • Administrator
  • 11,184 posts
  • Central Iowa
Posted 09 July 2007 - 10:11 AM
thanxs :burnout:
if it's still in decent shape, I'd try it with the jets already in it. I have a weber that came off a 1.9L Opel, and it ran awesome... I've even upped the jets on it since then...
#6 waimaks
waimaks
    Hey Boe!
  • 719 posts
  • NZ
Posted 11 July 2007 - 02:58 AM
Keep an eye on trademe. I distinctly remember seeing an ea81/ea82 weber carb adapter plate on there, guy had been selling new ones, on there for months.
More are bound to show up anyway.
#7 kiwi subbie
kiwi subbie
  • 932 posts
Posted 13 July 2007 - 01:19 AM
hey man can ya keep out an look for me :burnout:
#8 waimaks
waimaks
    Hey Boe!
  • 719 posts
  • NZ
Posted 13 July 2007 - 01:39 AM
Heres one.
http://www.trademe.c...sp?id=108496338
#9 erik litchy
erik litchy
    Leadfoot
  • 1,090 posts
  • Peoria IL
Posted 13 July 2007 - 11:10 PM
does the weber need the same fuel pressure as the stock carb?
#10 kiwi subbie
kiwi subbie
  • 932 posts
Posted 14 July 2007 - 06:21 AM
yea thats an good point aye? :burnout:
#11 suburpy
suburpy
    Soob Goob
  • PipPipPip
  • 101 posts
  • Adelaide
Posted 14 July 2007 - 07:13 AM
pressure for weber no greater than 3.5 psi I think
2.o litre cortinas often had the double pump webers, they have some hidouesly wierd jetting I think 165 165 mains from mem. GD has written out many times the basic jet set to start with for a soob.
Guy on Ebay aus has store called Gem Parts Australia sells many webers and has the adaptor plates as well as much more
