Synthetic Gear Oil
11 replies to this topic
#1 mheilmann
mheilmann
    New User
  • PipPip
  • 15 posts
  • Rapid City
Posted 02 December 2003 - 11:42 AM
I'm looking at replacing the gear oil in the axles of my '97 Legacy wagon (108K) with synthetic. South Dakota gets cold in the winter and hot in the summer. Any potential problems like leaking seals, etc?
#2 PAezb
PAezb
    Subaru Fanatic!
  • 407 posts
  • USA
Posted 02 December 2003 - 11:59 AM
Replaced both front and rear differentials with Mobil-1 75w-90 at 100K. Now have 130K and no problems. Winter (Minnesota) shifts seem a bit smoother with the synthetic gear oil - and I'm still running non-synth tranny fluid.
96 OBW/auto 2.5
#3 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 02 December 2003 - 12:32 PM
I use Mobil 1 75w-90 as well in the diffs and have been very pleased with it. I am using valvoline sythetic blend ATF in the tranny. I still change both every 30k.
#4 DerFahrer
DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 02 December 2003 - 03:08 PM
Search some of my posts, and you will find that I am a die-hard dino oil fan. I have had nothing but bad experiences with synth gear oil in my Legacy...
However, you up in the colder regions of the country have nothing but praise for it...
So here is my theory on dino vs. synth: Synth is okay in colder climates, where the thickness of cold oil can make up for the slipperiness of the synth stuff. But here in hot weather, the oil gets thinner and the same slipperiness does not allow proper gear synchronization....
#5 Snowman
Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 02 December 2003 - 05:17 PM
I know I've said this before, but switching to Quaker State synthetic 75w-90 in my subaru was one of the best choices I made relating to my car, and definitely worth the cost. Cold weather or hot, not a single drip from the tranny or the rear end (just the engine:rolleyes:), and she shifts SOOO much smoother now. It's also pretty easy to shift right when she starts up in below zero weather, where before with dino oil, it was difficult to shift for the first few miles in temperatures below freezing.
And I did the switch on a tranny with 150,000 on it, which is WAY after you're supposed to do it.
#6 nickb21
nickb21
    Subaru Fanatic!
  • 566 posts
  • Hunterdon County
Posted 02 December 2003 - 11:27 PM
I know I saw this mentioned in a seperate thread, but I'm not all that clear..
If you use a synth gear oil in a 5MT, should you, or do you need to add a friction modifier? Same goes if you have the VLSD, since the lsd isn't mechanical, should you use a friciton modifier anyway, or are you better off without it? :-\
#7 Snowman
Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 03 December 2003 - 12:58 AM
The oil I'm using says it works for regular transmissions and diffs, and those with LSD.
#8 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 03 December 2003 - 02:13 AM
Danish winters can get pretty cold and I have found a BIG advantage using synthetic.
Redline is a notch better than Mobil, but both beat all the competitors hands down.
Redline 75W-90NS in the manual 'box, shifts very smoothly in hot and cold weather - M1 lags little in extreme cold. Both have the friction modifiers in them already. Redline make a 75W-90 for non-LSD diffs, which would be good to use in conjuction with an autobox.
#9 nickb21
nickb21
    Subaru Fanatic!
  • 566 posts
  • Hunterdon County
Posted 03 December 2003 - 02:44 PM
Thanks for the info, guess I should have read the mobile 1 bottle a little more closely. It doesn't get all that cold here, but I figure I'll give it a try the next go around.
Thanks.
#10 sprintman
sprintman
    USMB Regular
  • PipPipPip
  • 105 posts
  • Canberra Australia
Posted 03 December 2003 - 08:30 PM
setright I use RL exactly as you posted. Best change ever for my Outback.
#11 remarcable
remarcable
  • 6,061 posts
  • South Carolina
Posted 03 December 2003 - 11:49 PM
I've used the Mobil 1 75w30 in the rear differential for over two years with no problems. The power transfer is smoother and I get less binding in turns when the tires are out of measure with each other.
I use valvoline synthetic in the front diff because subaru suggests something a bit thicker than 75w 90 in the front differential. I forget the weight, 85w 90 or something similar.
I use regular ATF fluid because it is cheap and I hate my transmission.
#12 Setright
Setright
  • 3,176 posts
  • Denmark
Posted 05 December 2003 - 12:54 PM
Go Sprintman!
