AC Blows Warm when I am at a Light
18 replies to this topic
#1 msmithmmx
msmithmmx
    Subaru Nut
  • 738 posts
  • PA
Posted 10 July 2007 - 07:13 AM
A timeless question. Since I swapped out my AC compressor it will not blow cold air when I am just idling. When I am cruising down the highway its the artic blast. I filled it myself with the stuff off the shelf at Walmart. What is my problem?
#2 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 10 July 2007 - 07:46 AM
DId you use the proper pressure gauges?
Did you evacuate the system?
nipper
#3 uniberp
uniberp
    mpmi
  • 703 posts
  • Walker, MI
Posted 10 July 2007 - 09:06 AM
I don't know what your problem is...
...however, you cannot properly charge an AC system without some expensive equipment, namely first off a high quality vacuum pump. The system must be evacuated as completely as possible before charging with refrigerant and oil.
Simply adding refrigerant to a system that has atmospheric moisture will not give you an adequately working system. Plus, the mixture of the moisture from the air and the refrigerant will create an acidic mixture that wille at away your compressor seals.
It is ususally not worth it for a person to invest in the vacuum pump, the gauges, the fittings, for a one time recharge, plus there is a big learning curve to doing it well.
It's best if you take it to a shop. They will charge $50-$100 for a evac-recharge, and point out any leaks you may need to fix.
There are many threads here about Subaru AC.
#4 ericem
ericem
    First Gen Legacy Master
  • 2,477 posts
  • CANADA Maple,ON
Posted 10 July 2007 - 10:57 AM
you probably overfiled it. If you used the same refrigerant you don't really NEED to vacuum the system. It is alot more difficult to spin hte ac when its overfilled so the clutch engages then just disengages when it feels it is to difficult and putting to much of a load on it. But i guess when it is reving higher it will keep it engaged.
#5 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 10 July 2007 - 11:13 AM
When stopped, are the fans turning on when the compressor turns on?
#6 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 10 July 2007 - 11:14 AM
I disagree :-p . The system was opened, and as a licensed AC tech, with (i am going to assume) a used compressor, he needs to evacuate it.
I am curious, how long did you have the dead ac compressor in the car, and how long was the system open for.
nipper
#7 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 10 July 2007 - 12:01 PM
Forgot he mensioned he replaced the ac compressor. Maybe he forgot to tension the belts properly.
#8 msmithmmx
msmithmmx
    Subaru Nut
  • 738 posts
  • PA
Posted 10 July 2007 - 01:41 PM
I put the belts on tight, no method to that madness. The AC system was open for a week before I swapped it out and completed the job. I just filled her up I did not do a evac.
#9 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 10 July 2007 - 02:05 PM
You need to do a evac. Also your direr may be harmed as they really dont like being exposed to air.
nipper
#10 91LegLS
91LegLS
    User Awaiting Email Confirmation
  • 165 posts
Posted 10 July 2007 - 04:12 PM
I recently upgraded my '91 LS to R134a. What should the pressure be? My system was partially charged with R12 so the system wasn't exposed to atmosphere. Should the pressure specs listed on the compressor be used when changing to R134?
The A/C does eventually get cold but it seems like it should be colder. I work in a tractor trailer garage with refrigerated trailers and our A/C tech (30+ years experience) thinks that the freon pressure seems to be low based on watching my A/C being operated, but he doesn't have equipment to diagnose my car correctly.
#11 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 10 July 2007 - 04:13 PM
How about the fans? When stopped, are the fans coming on when the compressor engages? If not, it might explain why it works when you're cruising but blows warm when you're stopped.
#12 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 10 July 2007 - 04:25 PM
All you need is a gauge set and a thermometer.
So your running a mixed system?
nipper
#13 msmithmmx
msmithmmx
    Subaru Nut
  • 738 posts
  • PA
Posted 10 July 2007 - 04:46 PM
I am checking tonight
#14 91LegLS
91LegLS
  • 165 posts
Posted 10 July 2007 - 05:16 PM
nipper
No, the old stuff was removed.
#15 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 10 July 2007 - 05:33 PM
Then you can use a sert of charts ( google) to figure out what pressure your running by what temp your putting out. Better off using gauges though.
nipper
#16 msmithmmx
msmithmmx
    Subaru Nut
  • 738 posts
  • PA
Posted 10 July 2007 - 08:09 PM
Here is the deal, I put her in park on the driveway with the AC on. I opened the hood and here is what I saw. The 2 front fans on along with the AC compressor. What I did notice was this, my altanator belt is spinning just fine. My AC compressor belt is bouncing and jumping around. This may be my problem.......
#17 njdrsubaru
njdrsubaru
    is this thing on?
  • 1,198 posts
  • Old Bridge, NJ
Posted 10 July 2007 - 08:29 PM
i just swapped compressors myself on my 93 and recharged it with R134, idleing or not its always artic cold heheheheh
ps: shhhh but i also used the stuff from walmart :grin:
#18 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 10 July 2007 - 11:55 PM
:rolleyes:
#19 91LegLS
91LegLS
  • 165 posts
Posted 11 July 2007 - 11:30 AM
nipper
I went back to the mechanic that retrofitted my system. They checked the pressure and said I had the required two pounds of freon. They checked for leaks and found nothing. They added a dye into my system so that if any leaks develop over time, it will show up.
They inserted a thermometer into my vent and measured 60 degrees. I have the rare digital climate control unit that won't allow the temperature selected to go below 65. This system also regulates fresh air/recirculation automatically. There is a button marked "recirc" but if the unit wants fresh air, it will override the button pushed after 10 minutes. I also can't determine air flow direction. It allows me to select the temperature and that's about it. I can defrost the windshield, select low or high fan speed and learn the outside temp. It basically says "you tell me what temp you want and I'll deal with everything else".
