Experience with Sea Foam?
11 replies to this topic
#1 nathan.chase
nathan.chase
    USMB Regular
  • PipPipPip
  • 87 posts
  • humboldt county
Posted 17 July 2007 - 11:54 PM
HI alll,
My ea82 is a little sluggish and needs a good maintenance. I got a can of sea foam and I was thinking of adding some to:
the oil,
the fuel
the master cylinder vacuum line into the engine
how have you used sea foam and what where the results?
Am I going over kill or not?
what would you do in any particular order?
vacuum, then oil and fuel for a tank before changing oil and the regular maintenance.
#2 beataru
beataru
    Subarus Catch on fire?!
  • 1,203 posts
  • Phoenix
Posted 18 July 2007 - 12:02 AM
well, I have heard that it cleans so well that cars will start to leak because it cleans all the grime off that was clogging them, go to youtube and search seafoam, youll sea what it does!!! smokey smokey!!
#3 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,482 posts
  • Roatán, Honduras.
Posted 18 July 2007 - 12:27 AM
I don´t have an Answer, but... I have had some Carb Dirt on my Weberized EA82. I´ve Tryed pouring almost every chemical additive to the Gas Tank (Carb Cleaners) and Spray carb cleaner directly to the Carb... The Trouble only decreases to almost dissappear, but then it comes again... :-\ ...a "Drown" carb on Higher Rpm´s at full throttle... I Hate that!
I was thinkin´ about to use a Seafoam can just to Clean the Carb... but I´m not sure How to Use it, ´cos I really don´t have the spare Time now to Take the Weber out and Learn exactly how to dissasemble it / clean it \ reassemble it...
So, this thread will be so Helpful for me too! :)
#4 The Dude Abides
The Dude Abides
    WileE Coyote Super Genius
  • 2,998 posts
  • West Des Moines, IA
Posted 18 July 2007 - 01:17 AM
Ok heres my 2 cents on seafoam
Ive been thinking about doing the same thing but heres the deal
Seafoam works plane and simple works great. My brother has a 1977 dodge power wagon full time 4wd x military truck 1 ton its a beast. It was alittle sluggish and he added seafoam to his carb just poured it down the intake and kept on the gas. Enough smoke to kill all the mosquitos. Was kickin crud out the tail pipe. Ran like a top fule . You could cherp the tires. Its that good.
Heres the problem though. The stuff in sea foam gets hot thats y it works so good it cleans out all the stuff with heat and chemical. If you put it in the crankcase and youve already got leaks more then likely ur gonna get them again. I could recoment starting with the gastank then into the intake however you do it. Id save the oil for last because thats whats gonna really get you. I havent gotten any yet but as soon as i can make it to the parts store im gonna pick it up and at least put it into the tank. Just be sure to read the directions very well
ben
#5 daeron
daeron
    Cunning Linguist
  • 3,600 posts
  • West Palm Beach
Posted 18 July 2007 - 01:40 AM
Do it the other way around, thru vacuum line first, then add to fuel (well, maybe add it to your fuel FIRST, so that its in the fuel you are burning while doing the vacuum line procedure) and then, if you feel like it, add to your oil about 500 miles before an oil and filter change.
Its good stuff, unless you are experiencing an abnormal amount of the Tick Of Death, I would recommend just sucking up half the bottle into a vacuum line and pour half the bottle in 6-8 gallons or so of gas.. in other words, maybe overdo it on the volume sucked into intake, and over concentrate it in the gasoline, just a little bit. Gives it a little more kick.
#6 Bucky92
Bucky92
    Drive Fast, Take Chances
  • 3,664 posts
  • New Milford
Posted 18 July 2007 - 04:03 AM
I completely sware by Seafoam.. I have never done the vac line trick yet..just some in the gas tank and some in the oil..Works wonders if you ask me...after running my Loyale with it for its TOD .. I have been told I have one of the queitest running EA82s around...if it wasnt for an exhaust leak you wouldnt hear him at all..OH and thats a car with over 200K on it. I use it in my XT6 as preventative maintenance since my motor has less then 30K on it.
If you read through the threads about Seafoam..TOD.etc you will see the use of that along with MMO and also ATF ( OH! this is directed towards the oil leak issue). These car leak..plain and simple...I had my EA82 resealed and 6 months later it was leaking again..not as bad though..It keeps the underside of the car from rusting;) . Dont let that detur you from adding it to the oil..I would rather have to add a quart once a month then listen to TOD..
#7 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 18 July 2007 - 05:14 AM
put a few ounces in your 1/4 tank of gas. run the car and dump a good portion down the intake. turn the car off and pour some in the carb/tb to soak
run the car and clear its throat
add the other 1/3d of the can through the oil and then change it within 100 miles
for carbs i would dump some in the carb to soak wheras fuel injected the vac line is ideal
#8 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 18 July 2007 - 05:45 AM
I'm another Seafoam guy, but use Marvel Mystry Oil in the crank case. You'll be amazed:eek: . Tim
#9 Uberoo
Uberoo
    Subaru Wheeler
  • 3,852 posts
  • lewiston,ID
Posted 18 July 2007 - 10:58 AM
I actually dont put it in the fuel system I once put 1/2 the bottle in my 200K saab in the engine(not alot of smoke so not alot of carbon) and 1/2 into the gastank.3 days latter my fuel pump died.it may be coincidence it may not..either way the pump cost $400(new oem...)
#10 subaruguru
subaruguru
    Scammer
  • 1,642 posts
  • Yakima Wa,
Posted 18 July 2007 - 01:43 PM
same here i used it to get the TOD to go away but about a week later the engine blew :eek: but that wasent the reson lol
#11 subyrally
subyrally
    Trust your Turbo-Lust
  • 2,892 posts
  • frederick, md
Posted 18 July 2007 - 02:39 PM
i swear by seamfom, its good stuff. we ran it in my friend's 90 toyota camry with about 225k in it, smoked like none other, but burned tires at the first intersection, lol.:burnout:
#12 nathan.chase
nathan.chase
    USMB Regular
  • PipPipPip
  • 87 posts
  • humboldt county
Posted 18 July 2007 - 11:40 PM
great ideas thanks for the continuing info and ideas.
I think I will add it too the fuel and vaccuum together and then put some in the oil and drive for a few hours to clear everything else before an oil change.
