ej22 TO EA81 FUEL PUMP ???
azbret
I have read some threads that state you should run larger wires back to the EFI pump. Looking at the wires that are there for my 84 brat they seem to be the same size. is there an amp differance between those pumps or is it just easier to run wires fron the relay instead of tying in the the brats harness???
I'm running the correct type of pump.. just was wondering why people say to run seperate wires back to it instead of using the exsisting wires by just soldering on the new connector for the pump. Then tying into the fuel pump wires in the harness up front at pssenger side door????
