ivantruckman Posted July 23, 2007 Share Posted July 23, 2007 i have a 91 loyale 4x4 auto, i think it has a torq bind problem. you can push it about 1/4 turn and it locks up, haven't gotten the engine running yet. is this torq bind hard to fix ? the body is very nice , no rust 140 k miles, great interior. i need an opinion from the subaru gods. thanks in advance Quote Link to comment Share on other sites More sharing options...
backwoodsboy Posted July 23, 2007 Share Posted July 23, 2007 Loyale? I thought all the A/T Loyales were FWD with pushbutton 4WD? You should be running it in FWD unless youre offroad (or in snow) .....and not be getting torque-bind, that is only on the Legacy A/Ts. Quote Link to comment Share on other sites More sharing options...
zyewdall Posted July 23, 2007 Share Posted July 23, 2007 Loyale? I thought all the A/T Loyales were FWD with pushbutton 4WD? You should be running it in FWD unless youre offroad (or in snow) .....and not be getting torque-bind, that is only on the Legacy A/Ts. Yeah, as far as I know, the loyales are all 4 wheel drive, not all wheel drive, so are not affected by torq bind (or you could say they are permanently affected by torq bind, just like any 4 wheel drive you drive on a hard surface in 4wd) Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 23, 2007 Share Posted July 23, 2007 put power to the bvattery and turn off the 4wd button. the car may have to roll to disengage. but it must be in 4wd right now Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted July 23, 2007 Author Share Posted July 23, 2007 thanks "fox dude", and" backwoodsboy" . and "Zman" it is indeed a 4 wheel drive, and the battery is very dead. i will try today to power it up and disengage it, it must be stuck in 4 w d. as foxman said, never had a 4x4 subie before . had a mild panic attack when i read about torq bind doing a search on old threads,thanks a bunch, Quote Link to comment Share on other sites More sharing options...
zyewdall Posted July 23, 2007 Share Posted July 23, 2007 put power to the bvattery and turn off the 4wd button. the car may have to roll to disengage. but it must be in 4wd right now isn't it vacuum driven, which means you need the engine running to switch states, not just a good battery? Z Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted July 23, 2007 Author Share Posted July 23, 2007 oh crap i think its a vacuum solenoid thats 12 volt fired oh boy, more checking, thanks for the heads up Quote Link to comment Share on other sites More sharing options...
zyewdall Posted July 23, 2007 Share Posted July 23, 2007 oh crap i think its a vacuum solenoid thats 12 volt firedoh boy, more checking, thanks for the heads up Yeah, you're going to have to get it running I think. But the good news is that theres probably nothing wrong with the 4 wheel drive. Z Quote Link to comment Share on other sites More sharing options...
88RxTuner Posted July 23, 2007 Share Posted July 23, 2007 1st, yes, it is a vacuum driven actuator. This does not reduce all chance of getting it out of 4wd without starting the engine, however... You should be able to remove the spare tire (if it's there) and look down at the top of the trans. On the driver side, there's a large vacuum motor bolted to the side of the trans. Follow the cable coming out of it to the lever on the other side of the trans... manually move the lever the other way from where it is. (may help to have an assistant to a) hold clutch in or bump car fwd and back to reduce the bind on the lever.) Hope this helps.. this will let you roll the vehicle without having to get it started. Quote Link to comment Share on other sites More sharing options...
nipper Posted July 23, 2007 Share Posted July 23, 2007 1st, yes, it is a vacuum driven actuator. This does not reduce all chance of getting it out of 4wd without starting the engine, however... You should be able to remove the spare tire (if it's there) and look down at the top of the trans. On the driver side, there's a large vacuum motor bolted to the side of the trans. Follow the cable coming out of it to the lever on the other side of the trans... manually move the lever the other way from where it is. (may help to have an assistant to a) hold clutch in or bump car fwd and back to reduce the bind on the lever.) Hope this helps.. this will let you roll the vehicle without having to get it started. If you dont have an assistant just jack up one wheel of the car off the ground. This will unload the 4wd. nipper Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 24, 2007 Share Posted July 24, 2007 1st, yes, it is a vacuum driven actuator. This does not reduce all chance of getting it out of 4wd without starting the engine, however... You should be able to remove the spare tire (if it's there) and look down at the top of the trans. On the driver side, there's a large vacuum motor bolted to the side of the trans. Follow the cable coming out of it to the lever on the other side of the trans... manually move the lever the other way from where it is. (may help to have an assistant to a) hold clutch in or bump car fwd and back to reduce the bind on the lever.) None of this applies. AUTOMATIC it doesn't have a solenoid/lever/gear activated 4wd. All 4wd transfer is done within the 3spd trans via a hydraulic clutch pack. Excactly the same concept as the full time units except pressure is only supplied to the clutch for 4wd operation and only at full pressure(AWD auto units regulate variable pressure to the clutch) Unless the clutch is seized inside the trans(unlikely) then it is not in 4wd because the 4wd only operates when supplied with pressure from the trans pump.(engine must be running) I don't think the trans is any part of you're starting issue, if that's what you're having. What's the problem again? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 24, 2007 Share Posted July 24, 2007 make sure all the tires are the same size all the way around. torque bind will be caused by driving in 4wd on dry pavement, or a difference in tire size vs the front and rear axles both laterally or diagonally Quote Link to comment Share on other sites More sharing options...
nipper Posted July 24, 2007 Share Posted July 24, 2007 None of this applies. AUTOMATIC it doesn't have a solenoid/lever/gear activated 4wd. All 4wd transfer is done within the 3spd trans via a hydraulic clutch pack. Excactly the same concept as the full time units except pressure is only supplied to the clutch for 4wd operation and only at full pressure(AWD auto units regulate variable pressure to the clutch) Unless the clutch is seized inside the trans(unlikely) then it is not in 4wd because the 4wd only operates when supplied with pressure from the trans pump.(engine must be running) I don't think the trans is any part of you're starting issue, if that's what you're having. What's the problem again? The original poster said its a 4wd loyale, so we ahve to go by what he says ... http://www.cars101.com/oldsubaru.html#1992%20Loyale also says there that its push button on the fly 4wd. nipper Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 24, 2007 Share Posted July 24, 2007 i have a 91 loyale 4x4 auto i think it has a torq bind problem. you can push it about 1/4 turn and it locks up, haven't gotten the engine running yet. is this torq bind hard to fix ? the body is very nice , no rust 140 k miles, great interior. i need an opinion from the subaru gods. thanks in advance This is the original post. States clearly it is an automatic. Ivan, unless the clutch pack is totally welded toghether inside, there is zero possibility of it being in 4wd (it's not meshed gears, it's a clutch that requires pressure from a running pump) It is on the fly pushbutton 4wd(even more so that the Manuals). The button activates a solenoid in the trans to open and send pressure to the transfer clutch. Nice because it's almost instant 4wd engagement. If you can't get it to roll even in neutral, it's something else. Quote Link to comment Share on other sites More sharing options...
nipper Posted July 24, 2007 Share Posted July 24, 2007 This is the original post. States clearly it is an automatic. Ivan, unless the clutch pack is totally welded toghether inside, there is zero possibility of it being in 4wd (it's not meshed gears, it's a clutch that requires pressure from a running pump) It is on the fly pushbutton 4wd(even more so that the Manuals). The button activates a solenoid in the trans to open and send pressure to the transfer clutch. Nice because it's almost instant 4wd engagement. If you can't get it to roll even in neutral, it's something else. Ok you made it sound like you were talking about a gen2 clutchpack. nipper Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 24, 2007 Share Posted July 24, 2007 Ok you made it sound like you were talking about a gen2 clutchpack. nipper 3AT's clutch pack is virtually the same in function. only difference in operation is that it get's either no pressure(2wd), or full pressure(4wd). There is no modulation of the pressure to allow for "slip". But just as with the 4EAT, no running pump= clutch pack engagement= no 4wd transfer. Quote Link to comment Share on other sites More sharing options...
nipper Posted July 24, 2007 Share Posted July 24, 2007 SO it sounds like his clutchpack is fused together. nipper Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted July 24, 2007 Author Share Posted July 24, 2007 wow awsome response to my question, thank you all... this loyale is a 3 speed auto, when i went to push it (non running) the front wheels were binding after bout 1/4 turn, i removed the rear drive shaft. and it easily rolled up the ramps to the tow dolly. i will try to get it running today. I'm sure with the info i can at least get it running, thanks again for all the responses, you guys rock:headbang: Quote Link to comment Share on other sites More sharing options...
Hondasucks Posted July 25, 2007 Share Posted July 25, 2007 1st, yes, it is a vacuum driven actuator. This does not reduce all chance of getting it out of 4wd without starting the engine, however... No it's not! the MANUAL trannies are vacuum actuated, the autos have an electronic solenoid that activates a clutch pack in the transfer case, and I am pretty sure that no power = 2WD power = 4WD (Works basically the same as the newer AWD A/T except it's either on or off as activated by a switch, rather than duty-cycle controlled by a computer...) Quote Link to comment Share on other sites More sharing options...
