Break in new rotors?
13 replies to this topic
#1 ericem
ericem
    First Gen Legacy Master
  • 2,477 posts
  • CANADA Maple,ON
Posted 23 July 2007 - 02:18 PM
I ordered new rotors and pads all around. Now I remember reading somewhere that I need to break in new rotors? How is that done really, thats if it needs to be done. Thanks.
#2 nipper
nipper
    Semi Elite Master of the
  • 17,110 posts
  • Long Island NY
Posted 23 July 2007 - 02:19 PM
I just always drove the car :)
nipper
#3 Reveeen
Reveeen
    Certified Subaru Nut
  • 788 posts
  • Eastern Canada
Posted 23 July 2007 - 02:34 PM
At one time this was true, rotors came "new" perfectly smooth, and we were using asbestos for brake material, you avoided "panic stops" (if you could for 500 miles).
Now, rotors ship with a swirl pattern machined in the metal, and we are no longer using asbestos, go ahead and drive it.
#4 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 23 July 2007 - 02:59 PM
Thanks guys. Yes I noticed the swirl marks. If there not there, do I stil need to do break in? They are just plain brembo rotors.
#5 TheYeti
TheYeti
    Carp in Denim!
  • 448 posts
  • Arvada
Posted 23 July 2007 - 03:16 PM
You should be just fine :)
#6 jamal
jamal
    1000+ Super USER!
  • 1,015 posts
  • Los Angeles
Posted 23 July 2007 - 03:17 PM
The pads are what need to be bedded in. If they're stockish, it doesn't take much more than driving around normally. All you would ever want to know on the subject:
http://www.stoptech....ncontents.shtml
#7 nipper
nipper
  • 17,110 posts
  • Long Island NY
Posted 23 July 2007 - 04:02 PM
i still think its alot of bunk, otherwise anyone who lives in a high density area could go after a shop for not properly breaking in a set of pads.
For instance, where i live you have travel a good 5-9 miles to get to anywhere where you can do 60 mph (and i dont mean legally), let alone do hard stops without getting rear ended. What are most people supposed to do?
Also I have yet to see an SAE paper on this (please feel free to show me is someone has one).
Just make sure you have a good brake pedal, be cautious on the first stop to make sure things work, then go ahead and drive.
http://www.se-r.net/...es/breakin.html
http://www.cartalk.c...03/June/05.html
Tire rack recomendations for specific brands
http://www.tirerack....e.jsp?techid=85
though i do love the part about avoiding heavy braking for 400-500 miles. Unless you live in north dakota i think thats impossible.
http://www.pagidusa....n_procedure.htm
So many variations on the procedures, professionally i think a lot of it is a myth.
nipper
#8 porcupine73
porcupine73
    Obligate carnivore
  • 4,884 posts
  • Buffalo, NY
Posted 23 July 2007 - 04:20 PM
I did the stoptech bed in; seemed to work well. The way they described the bed in would go was how it went also. The stoptech bedin is probably a little agressive for the stock pads but it still worked. There was an EndWrench article that basically said bedding in was not required and is antiquated; can try to find if interested.
#9 nipper
nipper
  • 17,110 posts
  • Long Island NY
Posted 23 July 2007 - 04:31 PM
WOHOO i feel better :0
http://endwrench.com...tionFeb06EW.pdf
page 10
:-p :headbang: :banana:
nipper
#10 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 23 July 2007 - 05:35 PM
yay!!!!!!!!!!!! :banana:
I got some ACT ceramic pads BTW and plain brembo rotors. I can stop on a dime now with my crappy worn pads and worn discs. Imagine with nice new rotors and ceramic pads :eek: :clap:
#11 porcupine73
porcupine73
    Obligate carnivore
  • 4,884 posts
  • Buffalo, NY
Posted 23 July 2007 - 05:38 PM
Yep that was the article nipper. Excerpt:
Break-In
Noise and a hard pedal will be likely if proper lining break in procedures aren’t observed with modern friction materials. In fact, several experts we’ve talked to say that overlooking this procedure is the #1 cause of those complaints.
As one puts it, “It’s not unusual to see a perfectly good brake job ruined in the first five minutes by improper break in.”
We know people who still believe that the right way to seat linings is to really stand on the brakes a few times. That’s an anachronistic idea left over from the days when linings were supplied “green.” Panic stops would indeed get that friction material hot enough to cure it. But you don’t get uncooked pads and shoes from Subaru, or from any other manufacturer these days, for that matter, so this whole idea belongs to a bygone era, a time of ignition points and bias ply tires. It’s only of historical interest today, certainly not anything
you’d want to actually do.
The ideal way to start new linings off is to make 30 slow stops (spaced two minutes apart) from about 30 mph using light to moderate pressure. But nobody who works in a typical bustling shop is going to take that much time.
A more practical policy here is at least 10 moderate stops at 30-second intervals (you should be able to feel the action smooth out). Then avoid heavy braking for the first 200 miles.
#12 nipper
nipper
  • 17,110 posts
  • Long Island NY
Posted 23 July 2007 - 05:42 PM
I call that driving in a neighboorhood with stop signs.
nipper
#13 Reveeen
Reveeen
  • 788 posts
  • Eastern Canada
Posted 23 July 2007 - 05:50 PM
I *think* you will find that a fella living in Maple Ontario Canada:
http://www.mapquest....ate=on&zipcode=
Will get in the recommended "break-in" (brake-in?) about 2 minutes after leaving his yard (and before he can get to the 400 series parking lots found in that part of the world).
#14 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 23 July 2007 - 07:55 PM
Thats what I figure :lol:
