2000 Outback
3 replies to this topic
#1 Soup
Soup
    USMB Regular
  • PipPipPip
  • 35 posts
  • Ottawa, Canada
Posted 03 December 2003 - 12:24 PM
I bought a 2000 outback in October, just thought I'd share my experiences so far.
I purchased it from a auction in Montreal, (lease return). I gave it a good inspection, found that the dealer had removed a trailer hitch, (they butchered the removal, and cut off the harness), other than that, everything looked fine. I took it the garage for It's safety. The garage in their infinite wisdom thought the front rotors were worn, so decided to change them, without calling me! They installed UAP brake parts UH!
I then drove it to florida and back, with no problems, though I did note a intermittent knock in the engine at idle, but I didn't know if it was lifter noise or not.
Upon my return I purchased 4 steel forrester rims, and toyo winter tires, and a trailer hitch from my subaru dealer here in Ottawa, The trailer hitch was a snap to install. While at the dealer, I found it required 2 recalls, one for rustproofing, and one for the ECU replacement. No problem, when I returned the car for the recalls I told them to check the knock out in the Engine (75km, under warranty). When I picked it up they informed me that they had replaced the timing belt and tensioner, due to the tensioner leaking! What a bonus, not a penny out of my pocket!
Oh and the UAP brakes on the front... They warped. I got a refund and bought subaru brakes!
#2 alias20035
alias20035
    Subaru Fanatic!
  • 357 posts
  • Canada
Posted 03 December 2003 - 03:42 PM
The recall should have been for ECU reprogramming, not replacement.
All 2000-2003 Legacy/Outback's were recalled to rust proof the rear suspension.
Cam belt tensioner failures are a frequent occurence. Usually shows up as an intermittent or consistant knocking sound.
Expect cold temperature piston slap (knocking), all Subaru's seem to develop this. If the piston slap does not go away when the engine warms up it is not piston slap and could be a failing tensioner, or valve lifter clearance.
The 2000 Outback has small and weak brakes, Subaru installed larger brakes on the 2001 to reduce the warping problem. Subaru brake parts seem to be a lot better than aftermarket ones (performance parts excepted).
I recommend switching to the 01-04 model year brakes, in the long term it will save you money by avoiding the constant warping problems that plague the 00 model.
I also recommend that you have your Outback rust proofed at Rust Check on an annual basis. Road salt in Québec/Ontario is murder on cars...
#3 Commuter
Commuter
    Subaru Master
  • 1,857 posts
  • Niagara area, Ont Canada
Posted 03 December 2003 - 05:50 PM
HUGE supporter of Rust Check. I've been doing it on all my vehicles since the late 80's. Nice to see someone else recommend them.
Commuter
#4 Soup
Soup
    USMB Regular
  • PipPipPip
  • 35 posts
  • Ottawa, Canada
Posted 03 December 2003 - 10:58 PM
I'd like to switch to larger brakes, however I bought 15" forrester rims, and they won't fit over the larger calipers.. Hopefully the stock brakes are better than the uap stuff. I had the car sprayed at krown, and will every year. The car I retired (gave to family) was a 1984 Toyota Cressida, with no rust. It had been treated at Ming, Then when I bought it 6 years ago, I Krowned it every year.
Another thing to note, When I first bought the Outback, if you drove it fast, (120-140km) there was a nasty loud squeal from the front dash area on the right side. I found the rubber trim on the side of the windshield to be vibrating. I placed some tape temporarily on the trim and the noise went away. A couple of small dabs of silicone under the trim and problem is taken care of. I wonder if this is a regular occurance on the legacy, because there seemed to be nothing wrong with the trim, just bad design.
