Same shocks/struts on 98 Impreza RS as 98 Impreza OSB?
Not sure if this will help...
From the KYB 2006 Passenger Car Catalog:
SUBARU Impreza Outback KYB GR-2                  Front        Rear
1993-01 Sport Utility Wagon w/ABS    Right Hand 334255 (9)   334109
                                    Left Hand  334256 (9)   334110
1993-01 Sport Utility Wagon Exc. ABS Right Hand 235065       334109
                                    Left Hand  235066       334110
Note (9) is "New Part Number;Available Fall 2006"
AGX struts are also available for these models.
From the KYB 2006 Passenger Car Catalog:SUBARU Impreza Outback KYB GR-2                  Front        Rear1993-01 Sport Utility Wagon w/ABS    Right Hand 334255 (9)   334109                                     Left Hand  334256 (9)   3341101993-01 Sport Utility Wagon Exc. ABS Right Hand 235065       334109                                     Left Hand  235066       334110Note (9) is "New Part Number;Available Fall 2006"AGX struts are also available for these models.
I just bought the 65/66 fronts Exc. ABS. But I believe I have ABS. The 55/56 are new however, so that should be an indication that the 65/66 were ok prior to the new ones being introduced. Wonder what the difference is.
The only difference is probably the ABS version have a little welded on mount/clip thing for the ABS sensor wire to bolt into. So you could use the ABS struts on non-abs vehicle and just not use the mount point. But to use the non-ABS struts on an ABS vehicle you'd need a way to support the ABS sensor wire.
