Buggyroo and fitting 29's
7 replies to this topic
#1 bigo1966
bigo1966
    Subaru Fanatic!
  • 463 posts
  • Lafayette, Colorado
Posted 08 August 2007 - 02:43 PM
So who would have thought after all the cutting and banging and sawzalling the 29's still dont fit when I turn. They rub on the firewall part. By the sounds of it i need to extend the lower arm thingys (cant rememeber name) to push the tire forward a bit. Is this correct?
Thanks
Orion
#2 backwoodsboy
backwoodsboy
    vintagesubaruparts
  • 1,058 posts
  • upstate NY, in the woods
Posted 08 August 2007 - 03:06 PM
I fit 29s on my 4" lifted '86 brat.
Of course.... the bottom edge of my fender is almost non-existant from trimming, and I had to re-set my door hinges because of the fenderwall bashing :grin:
......you can do it!
#3 Numbchux
Numbchux
    EJ conversion addict
  • 6,874 posts
  • Saginaw, MN
Posted 08 August 2007 - 11:18 PM
Thanks
Orion
is the car lifted?
how much to they rub?
a little rubbing won't hurt anything, as long as it's not on anything sharp.
#4 bigo1966
bigo1966
    Subaru Fanatic!
  • 463 posts
Posted 09 August 2007 - 09:31 AM
Lifted-no
The hammer did the trick, i just dont know about flex and jumping. Ill see. Ill get some pics up soon. gotta go buy more tube after work :clap:
#5 Numbchux
Numbchux
  • 6,874 posts
  • Saginaw, MN
Posted 09 August 2007 - 02:30 PM
my 3" lifted wagon rubbed with 29s when flexing. you're going to have to beat the living crap out of that poor thing to get those to fit without a lift.
#6 Rooinater
Rooinater
    Official Thread Killer...
  • 2,285 posts
  • Gig Harbor
Posted 10 August 2007 - 12:01 PM
my 8" lift still rubs while flexing and turning at the same time, with 30" tires.
#7 pinksock
pinksock
    USMB is life!
  • 142 posts
  • Boise
Posted 15 August 2007 - 03:33 PM
Posted Image
here's a bad pic of my 29x8.50x15 TSL Super Swampers on my 85 GL wagon before the 4inch lift. the only way I got them to lift was by lift the car up with a jack putting the tires on and then letting the car down. in the rear where the bottom of the door and wheel well meet, the car was sitting on the tires. in the front I had the bottom piece of sheet metal off the goes from both fenders right under the radiator. the car wasnt drivable or movable AT ALL. You would have to cut so much off I dont think it would be worth it, I think you would ruin the car.
Tony~
#8 FlyB0y
FlyB0y
    Apprentice to Subie Gurus
  • 911 posts
  • Oregon City
Posted 20 August 2007 - 09:40 AM
Just FYI, I had 27" (27.8" mounted on 14" nissan 2x4 rims 6" wide) SS TSL's on my brat with a 3" lift, and after all the fender/wheel well "adjusting" they still rubbed in the back of the wheel well and that was with a 3" lift. I now have 26"(26.4 mounted same nissan rims) ATV tires and with no compression, still have little more than 1 1/2" clearance between the rear of the wheel well and the tire when the steering wheel is cranked. I think if you really want to try and do it with out a lift, at least consider going with the 6 lug conversion and 14" nissan or toyota wheels and the shortest swampers. No matter what it will still rub sometimes, the question is how much, and how often.:burnout:
Also with my 3" lift and 27 (28" really) swampers, because of the limitations of "massaging" the wheel well, I STILL had the leading corner of the furthest out side lugg of the tires getting clipped by the fender. Ever ride a dirt bike after the knobbys have rounded out? Same idea, IMO if you are rounding out the TSL luggs, not much point to having them as your losing a great deal of their performance by doing that.:eek:
