Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
1996 Legacy wagon/1997 Outback Same Lift Kit?
#1
Posted 18 August 2007 - 10:32 AM
#2
Posted 19 August 2007 - 11:52 PM
#3
Posted 20 August 2007 - 12:14 AM
#4
Posted 20 August 2007 - 12:49 AM
#5
Posted 20 August 2007 - 12:55 AM
#6
Posted 20 August 2007 - 01:10 AM
#7
Posted 07 June 2008 - 06:14 AM
Outback's struts can be fitted on Legacy no problems, but you will need blocks on your rear diff carrier otherwise you'll have negative camber.
You can use legacy's springs or new outback's standard springs - both are same part.
Cheers
AP
#8
Posted 07 June 2008 - 12:37 PM
I used 98 OB struts on a 91 Legacy wagon with no blocks and my camber was fine.
If the lift kit lifts has blocks for the tops of the strut and for the rear crossmember he should end up the same before vs. after the lift.
That is, unless the lift kit has *straight* strut top extensions. They should be angled to match the angle of the unibody mount, so the mounting point goes straight down instead of pointing out.
#9
Posted 07 June 2008 - 07:05 PM
now the real question is how, if you can, do you lift an outback?????
any hints??
#10
Posted 07 June 2008 - 11:37 PM
#11
Posted 08 June 2008 - 05:37 PM
Is to custom made lift blocks and longer bolts in sections, ie. diff carrier section, trailing arms, front cross member so on, by adding 1-4" blocks there then it'll lift.
You can use King raised springs will give you extra 1 1/2" lift. But I am not sure I think 96-98 Forrester Springs are same as raised springs? I am trying to find out - but hasnt been good.
Cheers
AP
it's easy to lift a legacy up by putting on outback struts. springs, if the come with used struts make the job easier, but they are the same on outback / legacy. then you can use outback wheels and tires.
any hints??
#12
Posted 08 June 2008 - 06:53 PM
