MPFI power?
6 replies to this topic
    USMB Reverend
  • 618 posts
  • Jersey Shore (Central) PA
Posted 05 December 2003 - 12:10 PM
what else could you do to get more power out of a mpfi other than:
air intake
spider intake
advance timing
better exhaust
better cam
port matching the exhaust
accel superstock coil
mallory 8mm plug wires
NGK plugs gapped to .45 - .50
what else?
also, how much HP do you think this would have and how much of that is from the cam?
I don't know the science of cams, can a reground one give me better power while keeping the power-band the same? (I don't want a low-end monster thats slow or a top-end beast that is gutless below 5 grand. Of course I am exagerating, but you get my point.:D
#2 Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 05 December 2003 - 12:29 PM
ask Will
hotter ignition w/a bit wider plug gap
#3 justyfied
    USMB Regular
  • PipPipPip
  • 39 posts
  • williamsport
Posted 05 December 2003 - 12:52 PM
the cylinder heads are where most of the potential power lies. given the same perameters. (cubic inch, compression, fuel) the problem is that most do not have access to a flow bench. i would try port matching the exhaust. you do not want to do this to the intake side as it will create more of a puddling effect. just a suggestion. good luck
    USMB Reverend
  • 618 posts
Posted 08 December 2003 - 08:25 PM
Check out my update at the top.
#5 svxpert
    Certified Subaru Nut
  • 777 posts
  • East Coast
Posted 08 December 2003 - 09:29 PM
How about a turbo?
#6 WJM
  • 7,828 posts
Posted 08 December 2003 - 11:22 PM
non turbo engines already have 9.5:1 compression. Its all about how much air and fuel you can get into the combustion chamber....from there, its kinda a science of compbusting it correctly, and then getting it out of the CombChamb quickly.
With some small reground cams, and your list of mods...and a spyder intake, id say 140 is not out of the question.
With turbo...money is the limit.
I read about these older F1 cars, making like, 1000~1500 HP, with small 4 cyl engines....73psi of boost on 102 octane!!!
    USMB Reverend
  • 618 posts
Posted 09 December 2003 - 12:42 PM
Alright, that seems to be all the mods for the engine right?
so, now the exhaust:
What would be a good diameter? 2 inches maybe?, I don't want steal from low end very much.
what measurement for a camgrind? again, I would like to rty to keep a good balance.
