differential oil Q?
2 replies to this topic
#1 Guest_oregonloyale_*
  • Guests
Posted 14 August 2003 - 01:36 PM
Im changing the rear and front diff. oil this weekend, car has 96K and never been done. The haynes manual syas something about putting some addative in the diff oil if I have a LSD and I dont know If I do? My 92 loyale ea82 auto tranny wagon has a push button AWD so I can drive on bare pavement if I want.Anybody know if I need the addative by my description?
#2 Guest_GlCraigGT_*
Guest_GlCraigGT_*
  • Guests
Posted 14 August 2003 - 02:17 PM
Okay, look at the label on the rear diff it it says in bold print LSD, then you do. If not then you don't.
As for your transmission, if there is a button on the shifter then it's 4WD not AWD. Driving on dry pavement in 4WD will cause damage to your drive train . Also if it's only a 3-speed automatic then it's most defiantly a 4WD not AWD,
#3 Guest_oregonloyale_*
  • Guests
Posted 14 August 2003 - 02:51 PM
Thanx alot and yes it is a 3speed auto. You have just sumed up another question of mine. I will look at the rear diff for the insignia.
:D
