croak Posted August 29, 2007 Share Posted August 29, 2007 I am doing a clutch and reseal this weekend was just going to get a remanned flywheel so I wasn't out the time to get it resurfaced (clutch has been slipping for a while now so flywheel maybe fried anyway) Kragen is the only one that can get it for me locally but they tell me there computer only shows it for 4wd turbo, no 4wd n/a. web site says #810 which the store says comes up as turbo. Question is do the turbo and n/a use the same flywheel?? thanks in advance croak '87 GL FI wagon Quote Link to comment Share on other sites More sharing options...
subaruguru Posted August 29, 2007 Share Posted August 29, 2007 i beleav so the splines for the engine are the same for all ea82s THE 4X4 TRANNYS ARE DIFFERENT!!!!!!! but as long as it is 2wd to 2wd and 4x4 to 4x4 you will be fine. PS why not just get the flywheel turned ? Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted August 29, 2007 Share Posted August 29, 2007 Shows the same thing on the partsamerica site. Might be it's supposed to be 4x4 AND turbo, or 4x4/Turbo 2wd? Just when you get it, make sure and measure the step to make sure it was turned properly. I got a Toyota flywheel turned once, it was supposed to be a .125" step, they ground it smooth. Slipped from the moment it was installed. Quote Link to comment Share on other sites More sharing options...
croak Posted August 29, 2007 Author Share Posted August 29, 2007 PS why not just get the flywheel turned ? one weekend to finish just easier I guess Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 29, 2007 Share Posted August 29, 2007 2wd Turbo and all 4wd use the same clutch kit and flywheel. Only 2wd, non-turbo is different. (1 inch dia. smaller disc) Quote Link to comment Share on other sites More sharing options...
