Need Hubtamer help!
4 replies to this topic
#1 alia176
alia176
    USMB Regular
  • PipPipPip
  • 87 posts
  • NM
Posted 07 December 2003 - 08:09 AM
Hey guys,
Those of you with the OTC hubtamer tool p/n 6490, can you help me out? I'm in the process of removing the rear bearing and a little stuck. I'm puzzled as to why the "forcing screw" 503052 isn't going into p/n 311881 easily. Could I have a bad p/n 311881? The threads on both parts look clean and not galled. It almost feel like the thread on p/n 311881 is slightly tapered. I'd say only about 1/4" of the forcing screw goes before it becomes extremely tight. I used the forcing screw to remove the outer hub with ease so I know the screw is in good shape.
Thanks for any help.
Ali
'95 Wagon
:banghead:
#2 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 07 December 2003 - 08:03 PM
Those two parts go right together with mine. Be sure to grease the screw when using it. You may have a bad part.
Best of luck.
#3 alia176
alia176
    USMB Regular
  • PipPipPip
  • 87 posts
  • NM
Posted 08 December 2003 - 07:00 AM
Yeah, I suspect one part was not tapped well from the manuf. I still got the job done using the supplied non hardened nut but I prefer to have all parts working...specially for the cost of this tool! Sure is a nice tool though.
Ali
#4 alia176
alia176
    USMB Regular
  • PipPipPip
  • 87 posts
  • NM
Posted 08 December 2003 - 09:17 AM
I talked to OTCTOOLS.COM cust service today and they'll be sending me another p/n 311881. No questions asked! I'm still reeling from it :-p
Ali
#5 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 08 December 2003 - 09:48 AM
That's great!
