Allied Armament Lift Kit - finished - details
20 replies to this topic
#1 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 02 September 2007 - 10:04 PM
Outback Gen 2
I am posting this for anyone who does an allied lift kit in the future. The allied instructions are fine, but there other details that need to be filled in.
Before you start if its an automatic, insepect the shifter cable. Try to brake the adjusting bolts loose. If it wont budge, order a new one. Do this before the build, otherwise you will come to a screaming halt waiting for the part. If its really stubborn you may need to repair the bracket.
You will need camber adjustment bolts, available at Tire Rack. You need the 3-4 degree bolts, as this will give you lots of room for adjustment.
2 Radiator hoses, as the sooby ones are too short.
The fuel line, return line and vapor line all need to be extended, otherwise there will be too much stress on the lines.
The Charcoal canister line and the vacume (or vent) line also need to be extended, same reasons.
Make sure there is slack in the harnesses, especially if you have added anything on your own.
You can keep the factory air (intake) boxes. There is a bracket that the box over the engine bolts to. This bracket also has a clamp for an AC line. You will remove this bracket, as it can not support the air box anymore. The airbox will be at an angle and be a little bit of a tight fit, but nothing is harmed. You can loose the AC clamp.
The accessory drive belt guard for the PS pump ( if you decide to keep it and you should) needs to have 2-3 inches trimmed off the front edge to clear the radiator fan bracket. It doesnt hit, but it really does look too close to be comfortable.
The dogbone motor mount (under the air box) needs to be lengthened, or replaced with a suitable longer one.
The rear sway bar is going to be flipped down if it is left as is. The rear radius bars need to be swaped, this will almost bring the sway bar back to its proper height and function. This is not mandatory.
The factory exhaust system may bang against the transmission subframe. This is easily correctable by removing one of the rubber donut muffler supports at the back of the car. This takes a tremendous amount of stress off the exhaust system. On my car the heat sheilds were lowered with standoffs to the proper height. Watch the 2nd O2 sensor.
After the car is assembled, the steering is going to feel like its binding. This will go away as the universal joints wear in. Be sure to grease them with lithium grease.
If there is a driveline vibration (mild) the carrier bearing may need to be shimmed with a few washers.
I would STRONGLY recomend installing new struts at this time. If you have a tired strut (murphies law they never blow as a set) with the additional height handling can be interesting.
Get used to how the car handles now (it doesnt change too much). For some odd reason the car seems a little more agresive :clap:
nipper
#2 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,102 posts
  • NH
Posted 02 September 2007 - 11:00 PM
Total cost after everything was said and done with a breakdown?
#3 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 02 September 2007 - 11:05 PM
That i can't tell you, because i had other things done at the same time.
It's not too hard to figure out though, as there arent many parts other then the Allied kit.
nipper
#4 subeman90
subeman90
    Soobologist
  • Moderator
  • 2,805 posts
  • Akron PA
Posted 03 September 2007 - 11:30 AM
please submit for the USRM would ya? :headbang:
and Pics dam it!:banana:
#5 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 03 September 2007 - 12:47 PM
i would love too, but i dont know how right now. (bad morning, E.R at the wee hours, serious pain meds) so someone else fell free. i wont mind.
Pictures are coming, they just have to wait till i got over this health hiccup.
nipper
#6 subeman90
subeman90
    Soobologist
  • Moderator
  • 2,805 posts
  • Akron PA
Posted 03 September 2007 - 02:29 PM
no problem chief....get better and worry about this later :headbang:
#7 mtnbob
mtnbob
    USMB Regular
  • PipPipPip
  • 86 posts
  • Spartanburg SC
Posted 04 September 2007 - 06:14 AM
I just want to say thanks Nipper!!! I'm trying to find Scorpion springs right now so I can do put my lift kit on (Rennick is telling me they are on 1 month backorder:eek: ) If anyone has an idea where I might find lift springs for my Outback, send me an email!
At least the shop I am using is letting me take pics as they progress:)
***UPDATE*** Springs are on their way!!!!
#8 Andyjo
Andyjo
    I'm Not Austin!
  • 1,808 posts
  • Windham NH
Posted 06 September 2007 - 08:13 PM
Serious pain meds make writing instructional technical writing better ;)
hope all is well nippster, car looks HOTT!!! :headbang:
#9 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 08 September 2007 - 05:04 PM
You Asked For Them
Posted Image
Drive Belt Shroud to be trimmed
Posted Image
Loose this air box bracket
Posted Image
Air Box over engine
Posted Image
Air intake hose
Posted Image
Air Box Interference
Posted Image
Fuel Lines to be extended
Posted Image
Charcoal Canister lines to be extended
#10 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 08 September 2007 - 05:06 PM
I had to do this quick and dirty on the street.
Posted Image
Posted Image
#11 xrturbo
xrturbo
    Subaru Fanatic!
  • 368 posts
  • allentown
Posted 12 September 2007 - 10:45 AM
Nice!! Are they still doing the kit? I had heard at one point they were stopping temporarily due to lack of requests??? I was going to pull mine off the road in spring and start making my own stuff.
#12 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,101 posts
  • East Coast
Posted 14 September 2009 - 10:30 AM
Hey nipper - got any pic's to attach of your lifted OBW? A friend is looking at a legacy and I wanted to show him a lifted one.
#13 Bigbusa
Bigbusa
    USMB is life!
  • 256 posts
  • NY
Posted 14 September 2009 - 11:35 AM
lts see some pics!!!!!!!!!!
#14 bheinen74
bheinen74
    Banned
  • Banned
  • Pip
  • 0 posts
  • central Iowa
Posted 14 September 2009 - 12:26 PM
Good write up on the little things. Radiator hoses, vacuum, gas lines, etc. Everyone who is adding a lift kit first time ever, just assumes nothing besides the kit is needed. We all know there are many little things to overcome, and you covered them quite well..
thanks
good job.
#15 airgne
airgne
    New User
  • Pip
  • 5 posts
  • Oak Harbor, Wa
Posted 29 October 2009 - 01:17 PM
so anyone know what happened to allied? looking for a lift kit for my 91 legacy, but cant seem to find allied anymore.
#16 nipper
nipper
  • 18,195 posts
  • Long Island NY
Posted 29 October 2009 - 03:56 PM
Sadly it went poof
http://forums.gunboa...ad.php?t=133350
#17 airgne
airgne
    New User
  • Pip
  • 5 posts
  • Oak Harbor, Wa
Posted 29 October 2009 - 06:45 PM
damn. who maks the lift kits for EJ's now?
#18 monstaru
monstaru
    wow, relevance....
  • 4,453 posts
  • OlyWa
Posted 29 October 2009 - 10:45 PM
thanks
good job.
actually, if they did their research properly .......they would not be surprised.imagine that.
a boyscout of sorts....
cheers, brian
#19 pabst90-ix
pabst90-ix
    Newbie
  • Pip
  • 1 posts
  • Colorado
Posted 10 September 2014 - 01:18 PM
Really sorry to bring back an old thread but i need some help asap. Hopefully someone here can give me some advice.
Here's what i got
94 legacy on 05 xt struts and lgacy springs. which give about a 1.5in lift
I just bought a set of SJR lift plates with an additional 1.5in lift.
Total 3in strut lift.
while installing them i have come to realize i absolutely need a body lift. There is just too much strain on the cvs/tierods.
How can i piece together or where can i find a body lift?
Please help guys, snow is already on its way to the rockies and i need to get this lift done asap.
#20 Prwa101
Prwa101
    Subaru Fanatic!
  • 832 posts
  • Sandy, OR
Posted 10 September 2014 - 01:37 PM
Pm'd
#21 WRicerX
WRicerX
    New User
  • Pip
  • 1 posts
  • fort wayne
Posted 11 November 2014 - 05:48 PM
Here's what i got
That's a bummer. I came on here to research that very thing. I have a 93 Legacy with 2000 Forester struts/springs. I was thinking about grabbing some 1 or 2" lift spacers from ncfab.net to put on in addition.
