paulpicard Posted September 8, 2007 Share Posted September 8, 2007 Need a little help here. 92 Loyale 5-sp, 4wd, NA engine, no A/C. Which of these connectors do I hook up to read the trouble codes? Green/green, white/white, or??? What are the yellow and black multi-terminal female conn.'s for? :confused: The other pic shows a couple of orphans originating in the Alt. harness. Can anyone help with these? Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted September 8, 2007 Share Posted September 8, 2007 This is the second time I've posted this today. Wonder if there'll be a third: If the CEL is on, do not plug any in. The ECU will flash the codes at you that are present. If you want to see what codes have occured in the past (only really useful if the CEL is intermittent), connect the white/black connectors. If you want to run a dealer-check mode, connect the green ones. There's actually a whole procedure for running the D-Check. So, its really not useful unless you know what the procedure is. NOTE: The CEL doesn't flash. There's an LED on the side of the ECU that flashes. Quote Link to comment Share on other sites More sharing options...
hush777 Posted September 8, 2007 Share Posted September 8, 2007 Connectors by alt. are for a\c hookups. Hush Quote Link to comment Share on other sites More sharing options...
paulpicard Posted September 9, 2007 Author Share Posted September 9, 2007 Thanks guys. hush, I sorta guessed they might be for a/c. Mike, I don't have any black and white connectors in that group pictured. Do you mean the pair of white ones or is there another set I have missed? (And thanks for your patience re: multiple answers:), yes, I want the history as the CEL is momentary at cold start and the fast idle is all over the place) ) Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted September 9, 2007 Share Posted September 9, 2007 I meant the pair of white connectors. Some cars they're black, and I forget which ones. Quote Link to comment Share on other sites More sharing options...
paulpicard Posted September 9, 2007 Author Share Posted September 9, 2007 OK, just to be sure of the procedure, connect the white connectors,(ign. off), turn ign. to "on", read stored trouble codes at the ECU LED, that's all. Right?? Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted September 9, 2007 Share Posted September 9, 2007 OK, just to be sure of the procedure, connect the white connectors,(ign. off), turn ign. to "on", read stored trouble codes at the ECU LED, that's all. Right?? Yup. Quote Link to comment Share on other sites More sharing options...
paulpicard Posted September 9, 2007 Author Share Posted September 9, 2007 Thank you, thank you. Much appreciated. Paul Quote Link to comment Share on other sites More sharing options...
paulpicard Posted September 11, 2007 Author Share Posted September 11, 2007 OK, got the following (historical) trouble codes: 11, 13, 21,24,31. First two refer to crank angle sensor. 21 is coolant temp sensor. Don't know what 24 is. 31 is throttle position sensor. That's according to the USRM item for a 89 EA82 SPFI so my questions are: 1) same codes for a 92?, and 2) car runs great after 2-5 minute warmup, CEL comes on only at cold start with a very erratic idle, should I worry? Quote Link to comment Share on other sites More sharing options...
azsubaru Posted September 11, 2007 Share Posted September 11, 2007 I would reset the codes first and see what comes up. It's possible but doubtful that all of those things need fixed. Code 24 is the Air Control Valve and it could cause your symptoms. From the USRM: 1988 and Later Models With Single-Point Fuel Injection -- CODE PROBABLE CAUSE 11 Crank Angle Sensor or Circuit 12 Starter Switch or Circuit 13 Crank Angle Sensor or Circuit 14 Fuel Injector - Abnormal Output 21 Coolant Temperature Sensor or Circuit 23 Air Flow Meter or Circuit 24 Air Control Valve or Circuit 31 Throttle Sensor or Circuit 32 Oxygen Sensor or Circuit 33 Vehicle Speed Sensor (VSS) or Circuit 34 EGR Solenoid or Circuit 35 Purge Control Solenoid or Circuit 42 Idle Switch or Circuit 45 Kick-Down (Detent) Relay or Circuit 51 Neutral Switch Continuously in the On Position 55 EGR Temperature Sensor or Circuit 61 Parking Switch or Circuit Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted September 11, 2007 Share Posted September 11, 2007 A CAS code will show up any time the car doesn't start the first time. Ignore those codes unless the car isn't running. Quote Link to comment Share on other sites More sharing options...
paulpicard Posted September 11, 2007 Author Share Posted September 11, 2007 Thanks, people. I had a hunch the CAS code would show if the engine wasn't running. If someone will walk me through the re-set procedure - I gather it's not just a simple battery disconnect? Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted September 11, 2007 Share Posted September 11, 2007 I gather it's not just a simple battery disconnect? That's what I do. Disconnect the battery, hit the brakes (the brake lights discharge any residual electricity), and wait about 30 minutes. Then I reconnect it. That will make sure the ECU doesn't remember anything. There is an actual procedure, but I never remember what it is. Quote Link to comment Share on other sites More sharing options...
paulpicard Posted September 11, 2007 Author Share Posted September 11, 2007 Thanks, Mike. Quote Link to comment Share on other sites More sharing options...
