Dustp115 Posted September 13, 2007 Share Posted September 13, 2007 my 79 wagon. I just bought this thing 2 months ago and gotta replace the clutch.. Ive done stuff like this before .. but just on my yotas never a subaru.. any tips or anything subaru specfic that I need to know about..I have not book just goin by my automotive know how..but what are the tourque specs for the plate and what not:burnout: BTW ill take pics of it this weekend its not a bad car for 50 bucks... Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted September 13, 2007 Share Posted September 13, 2007 its easy! The easiest way to do it is to remove the engine (which sounds like a lot but its not). First off, unbolt the y-pipe from the bottom of the engine. Then remove the radiator and hoses from the front of the engine bay. Then disconnect the 2 heater hoses, throttle cable, disty wires, alternator wires, main engine harness (2 small plugs), clutch cable and pitch stopper. Then unbolt the tranny and engine from one another, unbolt the engine from the crossmember and pull it out. Replace clutch and stuff it back in just the opposite of removal:banana: Fairly simple really, I can have that engine out of there in 20 minutes:headbang: Quote Link to comment Share on other sites More sharing options...
hatchsub Posted September 13, 2007 Share Posted September 13, 2007 Also while that engine is out you will want to replace the valve cover gaskets, oil pan gasket, rear main and oil pump gasket. Chances are they are all leaking. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 13, 2007 Share Posted September 13, 2007 yeah its easier to remove the motor and pull the clutch with the motor on a hoist. and while your at it do the valve cover gaskets and oil pan gasket. with the propper tools it shouldn't take more than a saturday. Quote Link to comment Share on other sites More sharing options...
