Hi guys. Long time no post. Everyone is doing great here. Anyway, I need help. I need to know of an internet site that I can order an ABS or Wheel sensor for my 91 Legggy. It's the right front one. Any recommendation which site? I called the local dealer there and it costs $150.00!!!:eek: Poor man can't afford that! :slobber:
Thanks for your help...:)
My 2001 Forester with 86k miles on her has the ABS Light staying on:
Dealer just says they have to hook up their ABS computer scanner to diagnose the problem. You might as well first do a visual inspection of all of the components to be sure wires are intact and no obvious damage exists to any of the conduits etc. My best guess is to check your front wheels first, since they turn and probably stress the sensor wires most. On the third sensor I inspected, I found an old wire breakage near the sensor that the previous owner (or some clown who broke the wire while doing a brake job) had soldered back together and wrapped electrical tape around….amazingly, it held for a few years. Here is a diagram of the general ABS setup, albeit from a different car: http://autorepair.about.com/library/illustrations/bl457a-lib.htm
You can easily and quickly pull out a wheel speed sensor once you remove the wheel. It has a black wire coming out of it, (perhaps with a white stripe if you look further up it near the wire clamp). You will find it mounted just in toward the engine on the splash shield by the rotor. Use a 12mm socket to take out the single retainer bolt. Then gently wiggle or pry with a screwdriver to pull out the sensor. It is a friction fit and sits in a hole like a bottle cork. So you can wiggle it out back and forth. Clean off the dirt/rust dust that might be covering the black sensor “cork” and the metal tip at the bottom of it. Visually inspect the teeth of the tone wheel, mine were clean as a whistle. The front left ABS speed sensor assembly is part # 27540AC100 and costs $120.77 shipped from subarugenuineparts.com. $3 cheaper than 1stsubaruparts. The wire from the sensor goes up through the fender into the engine compartment where it clips onto another ABS system wire with a standard wire connector.
[...]You can easily and quickly pull out a wheel speed sensor once you remove the wheel. [...] Use a 12mm socket to take out the single retainer bolt. Then gently wiggle or pry with a screwdriver to pull out the sensor. It is a friction fit and sits in a hole like a bottle cork. So you can wiggle it out back and forth. [...]
If only it always was that easy. :)
My experience in a "rust-belt" state is that a can of your favorite rust penetrant and a six-point socket might get the bolt out if you're lucky; if not, a series of drill bits, metal picks, and some cursing seems to work.:rolleyes: After that, you may have to hope that the steering knuckle didn't rust enough to jam the sensor in tight; if the sensor is known to be bad, you can be a bit more agressive than gentle wiggling or prying with a screwdriver.
I was replacing the bearing and I banged on the ABS Sensor [...] so I'm pretty sure I damaged it.
Maybe, maybe not; the light could be coming on because the ABS unit detects that the sensor resistance is out of range (due to a damaged wire or coil), or because the signal from it isn't sufficient. The first possibility might be a result of physical damage to the sensor. The second could be from sensor problems, but might also be caused by damage to the tone wheel or if the gap between sensor and tone wheel is incorrect.
I think I even used a screwdriver to punch it out, so the coil is the most likely suspect now...:mad:
Hi. That'd be the ABS 5.3i setup. Look for a white connector under the dash on the driver's side. On my '00obw, this white connector was sort of above the brake pedal. It was a 7 or 8 position connector, though only 2 or 3 had wires in them. It was sort of taped up (if it hasn't been used before).
There are two blackish 'test wires' taped with the connector. I put one of those wires into position '8' I think it was, which was the lower right pin when looking at the connector. Then when you put the key to run it flashes out the trouble codes.
A word of caution when trying to find the ABS test connector under your dash. Mine is a 2001 Forester, and the only open white connector is above the accel pedal. One by one I grounded each of the 8 holes, none of them produced any ABS light flashing when I turned the key to ON. 2 of the holes produced sparks, yikes. The ABS and CEL lights did go off, along with running lights and instrument panel lights. I found one toasted fuse, a 20 amp in the engine compartment box that the manual described as the Lighting fuse. That got my lights turned back on, but I am still twigging a bit about the CEL going off and not coming back on....it had been on due to my cat efficiency below threshold. Hmmmm. Anyway, the only open connector above the brake pedal was a small black one, and yes it had the 2 black wires nearby. I did not bother testing it since I had already produced sparks on the white one. Also, I removed the plastic kickplate near the driver's door since the Endwrench article mentioned the ABS test connector hides in there.....well, nope, it doesn't, that I could see. Anyway, I went ahead and replaced the front left ABS sensor since I was sure it needed doing. The ABS and CEL lights are off for now.
