Documented: The 1970 FF-1 Project car...
If you cut the seal, try to keep at least one section intact. Then cut it so you can get the profile of the seal. Some of the restoration places have profiles you can look at to try and match it up.
Thats what I was thinking I needed to do, thanks for the tip.
I'll talk to my windshield guy at work and see if I can get more input as well, he might even let me borrow some materials if need be for the removal :-p
Bad timing. Charlie has or had several of those,old,removed from cars,but still good enough to use if no other existed. I'll see if he managed to save any,I'm sure he tucked them away somewhere.
If he has one not worth using we'll cut that one for a cross section to match up new stock to.
That sounds like a plan. Heck, just a photo of that cross section is all thats really needed.
If you can get a seal thats already out and in tact, best thing to do is soak it in automatic trany fluid to try and revive the seal to make it flexible again. Same thing goes for interior pieces that were originally vinyl or the likes that have become hard form sun (like dashboards). Using petroleum jelly on them and let sit for a few days, softens it right back up.
:headbang:
I have a few chassis plugs I can test that with too...
Off-topic question:
I just discovered there are TWO versions of the 1977 FSM... The brown version (part number MSA-107) and the blue version (MSA-108). I presume the updated (correct) one is the blue one with the higher part number?
Off-topic question:
Probably. I also have the red supplement book for the Brat in '77 as well:-p
  • 2 weeks later...
Sorry for the lack of recent updates, been kind of busy (just finished working 12 days in a row for inventory :unamused: ) but I've got a couple of new shots of the car to keep you occupied. Oh, and I'm also soaking the windshield molding in petroleum jelly as recommended to make it softer for removal in the next week or two, and i've also put started putting together a binder (with photos and such) to show body shops.
Anyway, some pics as promised:
how hard is the rubber on the inside, if it is still soft enough just put pressure from inside out, ( i used to sit on the seats with my feet on the screen ), and get a friend to help roll the inside rubber where the pressure is to realease it, once it has started then it is easier from there.
Thierry
Thierry
The inside isn't too bad, its mostly the outside that has problems. The rear window molding is in better shape than the front too.
  • 2 weeks later...
Wow I am amazed just how monsterous that weber is compared to your stock carb. That stock one looks puny! If you are putting that on the ff-1 then it will really sing in the upper rpm band for sure!:slobber:
Oh yes its going on the FF-1, your carb is in FAR better shape than any of the carbs I have, and of course the best performing (and actually relatively easy to tune), but it might be awhile before its up and running :P
Did some more bodywork today, removed a couple little extra metal pieces, ground down some other weld spots and such.
Gave up on the windows, going to have to use someone to get them out, I just don't have the right tool to do it nor the skill the do it properly. The good news is the rubber is in VERY good condition from what I can tell, since its easy to work with and not dry in any way (the petroleum slathering helped I believe).
Very interesting indeed. Another trick I learned from back in my rubber band airplane days is that glycerin type hand soap help preserve rubber as well as make it more pliable. Not sure if that tip will help you any. Sounds like a very cool in depth project for sure. Glad you are taking you time and getting it right.
Success!
I got the windshields out! It just took a bit more silicon spray and force than I originally thought, but the rear one came out super easy, and the front one came out with a little bit of work...
The good news: The molding and windshields came out WITHOUT any damage! :headbang:
The bad new: I talked to a body shop this week, and they basically told me, "learn to weld" :-\
Anyway, here are a couple pics from today... The rear window area had a bit of rust that I just removed and put some paint on, hence the nice bright white color. The front window area was actually in good shape, no rust except one small spot, but it does have some dings on the passenger side area that need fixing:
Find another shop. Im sure there's a restoration shop somewhere in sacramento that will be willing to help you.
Just gotta be willing to pay for it. Sounds like the shop you talked to today didn't want your business.
