* * * * * 7 votes
Documented: The 1970 FF-1 Project car...
1621 replies to this topic
#651 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,155 posts
  • Oregon City
Posted 07 March 2009 - 10:11 PM
if you can get a pic of the threads, you might be able to retap them and fix them. Only way you're gonna fix it...
#652 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 07 March 2009 - 10:55 PM
I'm contemplating cutting off the bad first couple of threads (since they are "squished" which made them wide and too narrow to thread through) but it would put it close to the hole that the pin goes through...
I already used that procedure with a couple of other spots on the suspension I fubared where clearance wasn't an issue, but with these there is less wiggle room.
#653 XT6 Magic
XT6 Magic
    USMB Regular
  • PipPipPip
  • 102 posts
Posted 08 March 2009 - 01:53 AM
You can always grind the diameter of the damaged section down closer to where it was and then either use a thread file of the correct pitch and do it by hand or use a re-threading die. You should be able to fix them without having to cut any material off. Working with some other techs over the years has improved my skills in damaged thread repair:grin:
BTW I have been watching this thread from the beginning and it is looking great. Keep up the details and pics!
#654 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 08 March 2009 - 02:12 AM
Hmm, thread file, I'll have to check that out. Someone mentioned a thread die elsewhere and that seems like an expensive contraption.
#655 XT6 Magic
XT6 Magic
    USMB Regular
  • PipPipPip
  • 102 posts
Posted 08 March 2009 - 02:29 AM
These are the ones I have and they work great.
http://buy1.snapon.c...3&group_ID=1149
Posted Image
Edited by XT6 Magic, 08 March 2009 - 10:49 PM.
#656 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 08 March 2009 - 02:18 PM
Snap-on Update
The Snap-on.com website is not available due to a system upgrade that is now underway. This is part of our continuing efforts to improve our website for you, our valued customers. Please try again later.
LOL!!!
#657 naru
naru
    1000+ Super USER!
  • 2,161 posts
  • under the bridge
Posted 08 March 2009 - 03:03 PM
This one isn`t too pricey.Looks like it has your size.Should be able to buy just one thru a local jobber too.
http://cgi.ebay.com/...1QQcmdZViewItem
#658 subaru360
subaru360
    has no catchy title
  • 1,282 posts
  • Fleetwood, PA
Posted 08 March 2009 - 03:31 PM
To fix the threads, just file/grind down the mushroomed part and run a die down it to fix the threads.
#659 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 08 March 2009 - 07:24 PM
Oooh. If nobody at work has a set i can borrow, ill have to pick that up :)
#660 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 08 March 2009 - 07:26 PM
Oh, on a side note, I've been trying to reassemble my rear brakes today and i've found all the parts I picked up that were supposedly for the FF-1 (rear brake linings, brake cylinder, brake spring kit, etc.) all are wrong :(
I figure its because the suspension is actually a Wagon rear suspension and not a sedan rear suspension, which means all that stuff isn't compatible...
#661 bratman18
bratman18
    ADIDASubarus
  • 3,842 posts
  • Jefferson, Maine
Posted 08 March 2009 - 07:27 PM
Man that sucks!! So is the right stuff available? Where can you find it?
#662 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 08 March 2009 - 09:14 PM
I just found some wheel cylinders on ebay that look correct. Apparently the ones I bought before were for the front (so I have 4 fronts, no rears).
I've found the pins and springs for the brakes now, although one of the springs is not availible anymore, the other still is. However, brake shoes for these rears are non-existent :( (part number: 625301150 or 625300140)
#663 naru
naru
    1000+ Super USER!
  • 2,161 posts
  • under the bridge
Posted 08 March 2009 - 09:38 PM
These any good?
http://cgi.ebay.com....1742.m153.l1262
#664 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 08 March 2009 - 09:39 PM
These any good?
If that picture is correct... Nope.
And they need to be "wagon" ff-1 rear brakes. The coupes/sedans are wrong.
#665 naru
naru
    1000+ Super USER!
  • 2,161 posts
  • under the bridge
Posted 08 March 2009 - 09:48 PM
Looks like he uses the same picture for many shoe sets.Bet he has what you need.
#666 moosens
moosens
    Vintage Subathusiast
  • 1,757 posts
  • Bridgeport CT
Posted 08 March 2009 - 10:17 PM
I might have those brake parts but don't hold your breath.
#667 tailgatewagon
tailgatewagon
    1000+ Super USER!
  • 1,058 posts
  • Bozeman, MT
Posted 08 March 2009 - 10:41 PM
find a shop that relines brake pads and have them do it for you specail. its not that bad price wise(i have to do this on my 73 with drums up front) anyway you might look down that road.
#668 XT6 Magic
XT6 Magic
    USMB Regular
  • PipPipPip
  • 102 posts
Posted 08 March 2009 - 10:50 PM
Sorry the Snap-On link didn't work. Here is a picture of it from the site (seems to be working now).
Posted Image
#669 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 09 March 2009 - 12:54 AM
find a shop that relines brake pads and have them do it for you special. its not that bad price wise(i have to do this on my 73 with drums up front) anyway you might look down that road.
The linings are OK right now thickness wise, but I am concerned about down the road if I ever have to replace them... I'll probably have to go that route (unless someone like moosens has a pair laying around, or I can find some off of a parts car)
#670 naru
naru
    1000+ Super USER!
  • 2,161 posts
  • under the bridge
Posted 09 March 2009 - 04:15 AM
Might be incorrect,but, 1st Subaru says both of those numbers are still good. $19/set
https://www.1stsubar...art_number.html
#671 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 09 March 2009 - 07:31 PM
The numbers are still good, but they are not "active" and not availible. If I tried to order them, they will just be canceled (I work at a Subaru parts department FYI)
#672 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 09 March 2009 - 07:34 PM
I got the tie rod threads fixed today :banana:
My shop foreman had a whole die set, and another tech gave me a hand, got it done nicely :)
However, I did discover one of the front wheel bearings is shot :-\ Luckily I have a spare, and the tools and help to do the job! :banana:
#673 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 11 March 2009 - 08:18 PM
Thought you guys might find these photos interesting I found last night on a JDM blog: http://minkara.carvi...63/profile.aspx
Posted Image
yes, those are HID's! He shows how to install them in the blog, lol!
Posted Image
those are the SSR wheels I saw recently for sale on the yahoo auctions
Posted Image
check out his awesome exhaust setup!
Posted Image
LOL! Neon green with funky black painted hood...
Posted Image
...but check out his seat setup, I think i'll do something similar.
#674 kiwi subbie
kiwi subbie
    Certified Subaru Nut
  • 932 posts
  • Christchurch, New Zealand
Posted 13 March 2009 - 04:27 AM
That Exhaust looks Just like the Factory sports exhaust I have on my GSR :)
#675 Kostamojen
Kostamojen
    From FF-1 to BRZ!
  • 1,693 posts
  • Roseville, CA
Posted 14 March 2009 - 08:36 PM
Small update:
I just rolled the front fenders, repaired a bend on the passenger door (got a set of bodywork hammer/dolly's from Harbor Freight), and reinstalled the brake shoes on one of the rear brakes after rebuilding the original brake cylinders (I have one that needs a stud tapped though since it broke off, I basically re-used the original housing but used the internals from some of the "rebuilt" cylinders I found on ebay).
I have decided I need to buy my tires before the end of the month, the sales tax is going up next month here in California! I haven't found a place to repair the wheels yet, it looks like I'll have to go with the expensive "mobile repair" wheel specialist...
