Diff lock wont turn off
7 replies to this topic
#1 xforxlifex
xforxlifex
    USMB is life!
  • 188 posts
  • ma
Posted 09 December 2003 - 11:36 AM
Ok i used my diff lock in this recent snow storm and even though its in the off positions its still on on the dash and the diff is still locked up. What do I do? Could this be a ****ty ground or a ****ty switch?
#2 TROGDOR!
TROGDOR!
    Pastor of Muppets
  • 2,106 posts
  • Morgantown, WV
Posted 09 December 2003 - 11:45 AM
Are all your tires the same size, brand, and tread wear? Try driving onto a loose surface- gravel or wet grass- and try unlocking it there. Flip the switch to off and drive straight in both forward and reverse. If it turns off, then it's most likely a tire issue.
#3 xforxlifex
xforxlifex
    USMB is life!
  • 188 posts
  • ma
Posted 09 December 2003 - 12:03 PM
all tires of same brand, size, and wear.
#4 xforxlifex
xforxlifex
    USMB is life!
  • 188 posts
  • ma
Posted 09 December 2003 - 09:34 PM
anyone else have any input on this or have this issue?
#5 gravelRX
gravelRX
    Driven with both feet.
  • 885 posts
  • Roanoke, VA
Posted 09 December 2003 - 09:45 PM
I'll add to TROGs comment. Switch it in and put the car in reverse with the wheels straight, let the clutch out slow and flip the switch while letting the clutch take up the weight of the car. No? Do it again. Mines a bit slow sometimes. This is how mine switches off.
Jay
#6 Forkspear
Forkspear
    USMB is life!
  • 130 posts
  • Moriarty
Posted 09 December 2003 - 10:45 PM
I have the same issue sort of. My diff lock doesn't turn on. It used to work but then I pulled my engine a few times and now it doesn't work. I know I didn't get all the vacuum lines back in the right place. That might be part of my problem.
#7 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 09 December 2003 - 11:25 PM
Get on a loose surface, and 'wiggle' the car around in 1st, going slow, and then in reverse....it should unlock. Ive had to do that once with my RX...if you use the diff lock reguarly, like find a dirt road, and use it once a week or so, it becomes easy'er to engage and dissengage.
With regard to the vac lines...if you play with those long enuff, you'll figure out where they go! Thats what I've always done...but ive never messed with the diff lock lines.
#8 Forkspear
Forkspear
    USMB is life!
  • 130 posts
  • Moriarty
Posted 10 December 2003 - 12:13 AM
I figured out most of the vacuum lines. My heater works. There was one line that would act like WOT when i connected it to a vacuum source. I would connect it and start the car and it would rev up by itself. It went to 5k in a few seconds and would have kept going if I hadn't turned it off.
