Buggyroo and the Colorado 200
9 replies to this topic
#1 bigo1966
bigo1966
    Subaru Fanatic!
  • 463 posts
  • Lafayette, Colorado
Posted 02 October 2007 - 09:19 AM
I just wanted to invite anyone in the Colorado area to the Colorado 200 this Sunday at CORE, Colorado Offroad Extreme. The race starts at 9 and im hoping to finish the race. WE will see how the buggyroo does.
Orion
Details.....
www.coloradooffroadextreme.com
www.23deluxe.com
#2 Jerry DeMoss
Jerry DeMoss
    Pushrods 'O' Fury
  • 2,408 posts
  • Colorado
Posted 02 October 2007 - 10:23 AM
Sweet! Good luck man! I would love to see that thing in action.
#3 bigo1966
bigo1966
    Subaru Fanatic!
  • 463 posts
Posted 02 October 2007 - 11:33 AM
Not sure why this was moved to "non subaru off roading"...
#4 Rooinater
Rooinater
    Official Thread Killer...
  • 2,285 posts
  • Gig Harbor
Posted 02 October 2007 - 12:25 PM
what class are they entering you in? do you have to have all the fresh air pumps and stuff also? well lets see how the roo does, watch the front struts, if they aren't strapped they'll seperate on some of that terrain at high speeds. or not, cause you don't have large tires...
#5 bigo1966
bigo1966
    Subaru Fanatic!
  • 463 posts
Posted 02 October 2007 - 01:03 PM
Im entering in the "unlimited class". So im going against V8's and motorcycle powered mini rails. Safety stuff includes helmet, neck brace, 5 pt harness, wrist restraints, fire suit, rear facing amber light and some special venting system on the gas tank. Hopefully ill pass the tech inspection.
#6 Rooinater
Rooinater
  • 2,285 posts
  • Gig Harbor
Posted 02 October 2007 - 11:33 PM
good luck!
#7 Sweet82
Sweet82
    Elite Master of the Subaru
  • 3,274 posts
  • Salt Lake City
Posted 10 October 2007 - 09:45 AM
Soooooo......?
What happened?:confused:
Don't keep us in suspense
#8 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 10 October 2007 - 07:13 PM
What is this doing in "Non-Soob" land, that appears to be very much or should I say very little subaru???? Sounds like a blast:headbang:
Later, Tim
#9 GeneralDisorder
GeneralDisorder
  • 21,694 posts
  • Portland
Posted 29 October 2007 - 02:24 AM
Don't know if you have had this thing out yet, but at high speeds the first thing to go will be the front strut tubes. The McPherson strut gas shock tube is weak and the bottom will bend outward like a bannana right where it enters the knuckle. You need to add two or three more gas shocks on each control arm to absorb the impact from high-speed off road. The front will dive too far otherwise - bending the strut tubes and causing too much load to the strut spring - which will in turn toss the front end up in the air - bouncing you all over the place. If hit too hard, you can bend the tube so badly it will jam the strut cartridge in the down posistion - leaving you with no suspension travel at all on that side!
I've actually done this to my lifted wagon, and I know others that have as well. It helps that you have lightened it somewhat, but at the speeds you are going to encounter I fear it will still be a problem.
And.... I hope that thing has a Weber?? Stock Hitachi isn't going to give enough punch.....
#10 [HTi]Johnson
[HTi]Johnson
    Head Trauma, inc.
  • 1,522 posts
  • Coburg, Or.
Posted 24 March 2008 - 09:25 PM
Did you ever do this? I know it's an old post, but there wasn't ever an update.
