desertsubaru Posted October 10, 2007 Share Posted October 10, 2007 My brother has a 97 Cavalier 2.2 MPFI and it was showing a code for o2 sensor and TPS. We replaced tha parts and now at about half throttle it acts like the Rev limiter is coming on. Any thoughts? Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted October 10, 2007 Share Posted October 10, 2007 Could be a faulty fuel pump or filter. Pumps are a pretty common problem on those. Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted October 10, 2007 Author Share Posted October 10, 2007 Could be a faulty fuel pump or filter. Pumps are a pretty common problem on those. filter is new but the pump is really loud. Idles great and revs halfway but then as I said it sounds like a rev limiter. In my experiance when its the pump it usally dies slowly but I will checl pressure. thanks! Quote Link to comment Share on other sites More sharing options...
nipper Posted October 10, 2007 Share Posted October 10, 2007 You can also be in limp mode. Since you replaced two parts at once, put the old TPS back in and see what happens. nipper Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted October 10, 2007 Author Share Posted October 10, 2007 You can also be in limp mode. Since you replaced two parts at once, put the old TPS back in and see what happens. nipper I replaced them one at a time to see what one was maybe bad. I did o2 first with no change, then did Tps next with no change. I hate fuel injection! If it was my carbed sube it would have been fixed already. Quote Link to comment Share on other sites More sharing options...
nipper Posted October 10, 2007 Share Posted October 10, 2007 Its a 97? I missed that. Go to an autozone or something and have the codes pulled. If its in limp mode thereshould be a bunch of them. Does the spedo work? When was the last time the timing belt (I think it has one) was changed? How many miles? Can be a clogged cat. Hit the cat with your hand and see if it rattles (when its cold). nipper Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted October 10, 2007 Author Share Posted October 10, 2007 These cars have chains not belts and it only has 109k on it. Cat does not rattle when hit. We did the code thing and thats how we came up with O2 and tps. Speedo works and cat is new. Do you know where the lower O2 sensor would be? How do you get it off limp mode and how do you reset the ECU. Thanks nipper you are very good help! Maybe MAP sensor? Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted October 11, 2007 Share Posted October 11, 2007 Clear codes by disconnecting the battery for about five minutes, or go back to AZ and have them do it with the scanner. The lower O2s will be after the cat, sticking out of the side of the pipe right by the footwells. Were you getting a bank1 sensor1 or sensor2? Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted October 11, 2007 Author Share Posted October 11, 2007 That may be the problem. someone cut the old cat out and put an aftermarket back in with no lower O2 sensor. anyway to trick the ecu? Were you getting a bank1 sensor1 or sensor2. I get Both. Quote Link to comment Share on other sites More sharing options...
gbrand Posted October 13, 2007 Share Posted October 13, 2007 Check ignition stuff-on my 96 2.4 the coil packs etc failed and it would hardly run, but didnt throw any codes. Does the 2.2 have wires and a disty, or cioil packs and "integrated" ignition like my 2.4(almost impossible to check for good spark by "old time" methods) Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted October 13, 2007 Author Share Posted October 13, 2007 Check ignition stuff-on my 96 2.4 the coil packs etc failed and it would hardly run, but didnt throw any codes. Does the 2.2 have wires and a disty, or cioil packs and "integrated" ignition like my 2.4(almost impossible to check for good spark by "old time" methods)Coil packs. It turned out to be the ECU was turning on the rev limiter to soon. Thanks for all the help Quote Link to comment Share on other sites More sharing options...
