I want to know where the spark plugs are on this motor and if it will work
13 replies to this topic
#1 ericem
ericem
    First Gen Legacy Master
  • 2,477 posts
  • CANADA Maple,ON
Posted 10 October 2007 - 09:16 PM
I was looking at this motor and could not figure out what and where the spark plugs wheres and spark plugs are. Also will this motor be able to run off a EJ22E ECU and will the tcu work?? Comes with the tranmission you see there as well :)
http://www.jdmtigerj...apmi5lkgvvthrj2
#2 Towel Rail
Towel Rail
    USMB is life!
  • 138 posts
  • SW CR IA US NA PE
Posted 10 October 2007 - 09:22 PM
Look at the two "cutouts" in the valve cover of the middle picture. ;)
#3 Rooster2
Rooster2
    Subaru Master
  • 2,899 posts
  • Indianapolis
Posted 10 October 2007 - 09:23 PM
Blow up the pictures. You can see the sparkplug wires going through the valve covers.
#4 grossgary
grossgary
    Elite Master of the Subaru
  • Gold Subscribers
  • 18,055 posts
  • West VA
Posted 10 October 2007 - 09:29 PM
the picture won't load for me. i'm guessing it's either a late model EJ engine (like 1999), in which case the spark plugs enter through the valve covers on the side, not from the top.
if you can keep your current intake manifold or at least the wiring harness your ECU and TCU will not have any problems.
#5 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 10 October 2007 - 09:32 PM
That is exactly what my dad said about the spark plugs. Just wanted to verify thanks. I think were going to pickup the motor and compare the stock wiring on my car. Going to be fun having a turbo :banana::burnout:
#6 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 10 October 2007 - 10:03 PM
Did some research looks like this motor is going to be a huge hassle. I think a EJ20G from a 91' legacy with a LSD and all wiring is a much better option.
#7 jcniest5
jcniest5
    Eat, Live, Breath Subaru
  • 343 posts
  • The Twin Cities
Posted 10 October 2007 - 10:26 PM
What's the different between the EJ20 and EJ22? That aside, does anyone know where I can find new EJ22 engine? Not that I'm going to get one, just curious on how much it costs.
#8 jamal
jamal
    1000+ Super USER!
  • 1,015 posts
  • Los Angeles
Posted 11 October 2007 - 01:25 AM
it's a dohc with coil on plug.
If it came with the ecu and harness, and you had the wiring diagrams, it wouldn't be too bad, except for the fact that you would have to lose one of the turbos, find a single turbo exhaust manifold, buy a new crossmember then actually do the swap. That would involve adding wires to your harness from the turbo one (not included), and splicing it all into the plugs for the turbo ecu (also not included).
If you had everything it probably wouldn't be too hard, just a little time consuming, as you'd just have to read both diagrams and match up the corresponding wires. I'm probably going to do it one of these days.
Also, they say it's from an Impreza but only Legacies ever came with twin turbos.
#9 xrturbo
xrturbo
    Subaru Fanatic!
  • 368 posts
  • allentown
Posted 11 October 2007 - 05:47 AM
What year is the setup from. You have to be careful because alot of the early setups such as the 20G's are such low boost setups and take alot to mod to get the power up.
#10 porcupine73
porcupine73
    Obligate carnivore
  • 4,884 posts
  • Buffalo, NY
Posted 11 October 2007 - 08:17 AM
EJ20 is the 2.0L 4cyl; EJ22 is a 2.2L 4cyl. For a 'new' EJ22 engine, www.ccrengines.com would be someplace to check out. EJ22's are fairly readily available used for not too much cash.
Here's the side view pic. That place embeds/streams the picture into the page instead of linking it, maybe that's why it wouldn't show up. I like how the axles are just sawed off.
Posted Image
#11 jamal
jamal
    1000+ Super USER!
  • 1,015 posts
  • Los Angeles
Posted 11 October 2007 - 11:50 AM
like I said, a twin turbo does not fit in a LHD car due to the brake booster/MC and steering column.
However, if the 5-speed is included, that's almost worth getting for $550, because you can get used WRX manifolds and turbos for pretty cheap on nasioc.
Still, the costs are going to look something like this:
Turbo crossmember : $200
turbo: $150-$$$$
Exhaust manifold/up/down/tbe: $300
Wiring harness/ecu: $300
Misc things like a boost solenoid and replacement cut hoses and axles etc: $500
A $500 driveline can turn into a $2000 swap pretty quickly.
The TT motors have better flowing heads and bigger valves than a WRX motor from what I've heard.
#12 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 11 October 2007 - 07:49 PM
Lol a little cheaper actually. I think my best bet is the 91 leg drivetrain and engine with wiring. Also has the LSD.
#13 OB99W
OB99W
  • 3,315 posts
  • Ithaca
Posted 12 October 2007 - 07:04 PM
[...]I like how the axles are just sawed off.
Posted Image
Take a close look -- it's not just the axles! :eek:
#14 porcupine73
porcupine73
    Obligate carnivore
  • 4,884 posts
  • Buffalo, NY
Posted 12 October 2007 - 08:00 PM
haha yah I was looking at that after I first posted. Anything and everything that had a connection elsewhere was just snipped off. At least they're being efficient! Drive out the axle spring pin? Nah! hack off the axle! I'm sure at the minimum it is more fun that way for the person removing it!
