Electrical Issues
22 replies to this topic
#1 mr1t5abcde
mr1t5abcde
    New User
  • Pip
  • 7 posts
  • Aurora
Posted 18 October 2007 - 05:26 PM
I have a 2000 Subaru with "some electrical issues,:confused:
These are the symptoms:
First, my light switch ONLY turns on my head lights.
To get my running lights to come on, I have to turn on my parking lights (the switch on top of the steering column).
My break lights, when I depress my break peddle, it lights up all of my running lights along with the break lights.
Now with the lights on, and my parking lights on, my ABS warning light comes on, and disables my cruises control.
I borrowed a manual from the library with no real trouble shooting ability.
Can any one help please?
Thank you
:banghead: :banghead:
Thank you to ShawnW for getting me on to the CORRECT path. Greatly appreciated.
#2 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 18 October 2007 - 08:54 PM
Hi mr1t5abcde and Posted Image!
First, yes, on '00obw, the fog lamps work ONLY when the low beam headlamps are illuminated. They do not work when the parking lamps are on or when the high beams are on. There is an article on endwrench.com about this fact.
I too have an '00obw. I had a recent issue with ABS which turned out to be a poor ground at the power steering reservour bracket.
The other stuff you posted about lights sounds odd; I don't know maybe a bad ground or blown fuse somewhere? Either of those can cause odd things in lighting.
#3 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 19 October 2007 - 12:33 AM
For the taillight problem check fuses 7 and 12 in the main panel under the hood to see if they are ok. If they are good then check the relay for them in the same panel.
I suspect that the running lights are lighting up with the brake lights because there is a broken filament in one of the brake lights. A filament for the running lights is touching the brake light filament. Try replacing the lights in the rear to see if that corrects that trouble.
#4 nipper
nipper
    Semi Elite Master of the
  • 18,179 posts
  • Long Island NY
Posted 19 October 2007 - 08:16 AM
Wht he said about the filament. Remove one light at a time and see when the problem disapears.
nipper
#5 mr1t5abcde
mr1t5abcde
    New User
  • Pip
  • 7 posts
  • Aurora
Posted 25 October 2007 - 04:23 PM
Ok Gentleman,
I think that the information that I gave might been misleading, this is right out of the owner’s manual.
Headlights
To turn on the headlights, turn on knob at the end of the turn signal switch lever
First position
Parking lights, instrument panel illumination, tail lights and license plate lights are on.
Second position
Headlights, parking lights, instrument panel illumination, tail lights and license plate lights are on
Here is what is happening, I turn on my head lights on, and the only thing that comes on are my headlights and my instrument panel illumination.
NO parking lights, NO tail lights and license plate lights.
To get my parking lights, tail lights and license plate lights to come on I have to turn on my parking light switch.
With both parking light switch and the headlight switch turned on, my ABS warning light comes on, and disables my cruise control.
#6 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 25 October 2007 - 04:47 PM
Ew that doesn't sound good. Sounds like a potential wiring issue to me. Have you checked for any blown fuses? I might look later to see if the same fuse feeds the drain battery switch and the parking lamps normally. Maybe I would read the ABS code(s) to see if that reveals anything?
#7 nipper
nipper
  • 18,179 posts
  • Long Island NY
Posted 26 October 2007 - 08:38 AM
That sounds like a fuse, check at the fuse block first. Does the virgin switch on top of the steering column operate?
nipper
#8 mr1t5abcde
mr1t5abcde
    New User
  • Pip
  • 7 posts
  • Aurora
Posted 26 October 2007 - 02:56 PM
I have checked my fuses, and they are all working. The "parking light switch" works that is how I get my running lights to come on.
Any other suggestions?
Thanks so far!
#9 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 26 October 2007 - 03:35 PM
There may be a grounding problem causing this trouble. To see if that is so you could make a ground jumper and tie one end to the negative side of the battery. Then place the other end of the jumper on suspected bad ground points. If the trouble clears you know the area to look for a bad ground. The trouble may be in the dash area.
#10 mr1t5abcde
mr1t5abcde
    New User
  • Pip
  • 7 posts
  • Aurora
Posted 26 October 2007 - 03:59 PM
Cougar,
Where would I connect the grounds to? The lights? The fuse box? The headlight/ turn signal switch? I am not that good with electricty. The basics i can understand.
thanks
#11 nipper
nipper
  • 18,179 posts
  • Long Island NY
Posted 26 October 2007 - 05:51 PM
ok lets back up a bit.
there is an illumination relay that operates the parking lights. ANother possability is a bad combination switch. The main switch grounds out the coil for the illumination relay. The current then goes through the parking light switch, to the 10 amp fuse, then gets distrubuted to all the marker lights.
What I would do is find the 10 amp fuse and pull it. With the switch off, there should be no voltage on either side of the fuse. Turn on the switch. Now there whould be voltage at one side of the fuse (with the car on of course).
FYI:
If the parking light switch is "on", the illumination relay is bypassed, and the parking lights will come on. So you have a bad illumination Relay.
(I need to start traveleing with my haynes manual it seems so I can answer these things quicker).
nipper
#12 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 26 October 2007 - 06:08 PM
nipper
are you on the road or are you suggesting you could plan a trip traveling from one repair to the next.??
#13 nipper
nipper
  • 18,179 posts
  • Long Island NY
Posted 26 October 2007 - 06:14 PM
hehehe i just got home. wed/thur is my weekend, when i get to see the other half. Sadly i get to see the other half in New Jersey (and we all know how NY'ers love NJ :P)
nipper
#14 johnceggleston
johnceggleston
  • 6,712 posts
  • Virginia
Posted 26 October 2007 - 06:25 PM
nipper
let's see , which is better, ny alone or nj with the other half....????? hmmmmmm... i know what i'd choose.
#15 nipper
nipper
  • 18,179 posts
  • Long Island NY
Posted 26 October 2007 - 06:31 PM
pennsylvania?
nipper
#16 mr1t5abcde
mr1t5abcde
    New User
  • Pip
  • 7 posts
  • Aurora
Posted 27 October 2007 - 09:39 AM
Gentlemen,
johnceggleston and nipper,:banghead:
PLEASE,
I need help with my electrical . . . not your travels?!?!?:horse:
thank you.
Nipper you have provided the most information. I gather you like Hayes manual? Where would i find the illumination relay within the manual?
is there a year specific manual for 2000 Outback's. What would be next in line to check?
#17 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 27 October 2007 - 10:56 AM
Cougar,
thanks
The grounded jumper lead is used to replace any suspected bad ground point, which is the frame and body of the car usually. Subaru uses a switched ground to turn on lights usually. This means power is tied to the lights, sometimes via a relay, and the switch controlled by the driver makes contact to ground in order to turn on the lights. You would not want to tie a ground jumper to the fuse box area since that is the HOT side of the circuit and you would short out whatever you tied to. If there is a bad ground somewhere then by placing the ground jumper in the car body area that has the bad ground will usually correct the trouble and you then know were to look for the trouble. If your brakes lights are working ok then the grounding in the rear area is probably ok.
Unforunately I do not have access to my service data right now to look over the taillight circuit and won't have them until Wednesday. The problem problem my be with the illumination module as Nipper suggested. If you haven't checked the fuses under the hood then check those for a bad fuse.
#18 gbrand
gbrand
    Subaru Fanatic!
  • 385 posts
  • fort worth area
Posted 27 October 2007 - 07:57 PM
OK, my 2 cents here. As an engineer who has worked in the electrical test business for almost 25 year, but learned my basic electricity between the ages of 8 and 10, I have a mild little ranting to do. thef ear and misconception of electricity has probabaly cost more people time, money and even thier lives that a simple approach of what to do-and not do-in trouble shooting.
OK, in your case, dealing wih 12 Volts is safe, and the main thing to remember when dealing with electricity is it is like water flowing through a pipe(sort of) the electricity flows from a high elevation (potential) to a low elevation(many call ground) and then the battery(or alternator or generator) acts as a "pump" to bring the leectricity9water0 back to the high elevation. So if a wire goets broken, no electricity flow and no lights9or horn or stereeo orwhat ever you are trying to power as no current can flow, and it you get a short, wiring touches something it isnt suppoesed to, current flows in apath it isnt supposed to and causes current low to ground or what ever. At all costs if the simple stuff doent solve buy or borrow a wiring diagram-and follow the "pipes' to see ehare the elecricity should flow.
OK, FIRST check all fuses related to the ciruits that are having prolems. And dont forget there are fuses in addition to those under the dash, at least in my 91 Legacy there is an additional fuse box in the engine compartment. If they are all OK(I suspect they may not be) check your bulbsto make sure they are good. Don't relay on visible inspection, use an ohmeter. Aslo check for proper power AAD ground connections at your socket-if you don't have a multimeter purchase one-they can be had very cheaply-granted there is someyou get what you pay for but I would take having a 5 buck multimeter for trouble shooting lighting problems over waiting till next pay check to buy a 190 dollar Fluke model. Here is a link on how to use. As has been said earlier, the tail/stop lights are 2 filimants with seperate sources connected to a common "ground"., if that ground connection is broken one circuit will feedthe other. LMy bet is a blown fuse and orabad combo switch. Butthat is a guess.
http://autorepair.ab...a/aa063001a.htm
Let us know hwat you find out
#19 mr1t5abcde
mr1t5abcde
    New User
  • Pip
  • 7 posts
  • Aurora
Posted 29 November 2007 - 08:47 PM
To everyone that helped . . . THANK YOU:clap:
I finaly took my car to the garage. I found out that that it had three things wrong, and they were WAY over my head:-\
First my headlight switch was bad
second there was a computer that went bad
and the last was a short in the tail lights!
I greatly appreciate everyones help
Thank you:headbang:
#20 eastwestboy
eastwestboy
    USMB Regular
  • PipPipPip
  • 42 posts
  • canada
Posted 30 November 2007 - 12:06 AM
You sure you were not taken for a ride? How should a computer problem cause a bulb not lighting? Electricity goes from battery to relay,switch, bulb and back, the ECU does not control the lights. Glad he didn't change the blinker oil. :clap::clap:
#21 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 30 November 2007 - 12:51 AM
Thanks for the update and glad you got it fixed. You're welcome for the info.
#22 OB99W
OB99W
  • 3,315 posts
  • Ithaca
Posted 04 December 2007 - 11:58 AM
I realize that this might not have applied to the original poster's problem, and that his troubles have been resolved, but anyone reading this thread due to tail light problems may want to also read http://endwrench.com/images/pdfs/ErraticInsideNov07EW.pdf .
#23 mr1t5abcde
mr1t5abcde
    New User
  • Pip
  • 7 posts
  • Aurora
Posted 05 December 2007 - 05:25 PM
The computer they replaced was for the cruise control. When I truned my lights on, and my parking lights on to drive at night, my ABS warning light would come on and shut off my cruise control.
No, I do not think I was taken for a ride
Thank you
I apperciate your information. I talked it over with the boss of the garage.
