How similar are the EA and EJ motors?
5 replies to this topic
#1 milestoempty
milestoempty
    New User
  • PipPip
  • 29 posts
  • Severn
Posted 25 October 2007 - 08:41 AM
I cant really seem to find any info on this... I know the EA hasta be alot different simply because the plugs are on the top and not the side. But I was wondering if it were possible to make a hybrid out of both motors?
#2 s'ko
s'ko
    RIP
  • 1,722 posts
  • Los Angeles
Posted 25 October 2007 - 10:10 AM
almost 99.99999% sure it will not work. different series of motors w/different casting and short blocks.
besides you could probably pick up a cheap EJ22 for the same price as an overseas EA82t.
Things like oil sensors or temp sensor might work, but if you are talking about head swaps and internals, I don't think so.
BW
#3 daeron
daeron
    Cunning Linguist
  • 3,600 posts
  • West Palm Beach
Posted 25 October 2007 - 11:39 AM
wholly, totally, utterly incompatible. Completely different sizes of everything.
Absolutely, no. Just being clear :) This is coming from someone who has seen (via internet) a Datsun L-series inline six block (Z-car) running on a cylinder head made from three sections of two different 240SX (dohc) cylinder heads, so if it MAYBE could be done I would say so. It can't. The alternator, maybe power steering pump and AC compressor, MAYBE starter if you were REALLY inventive, MIGHT could be retrofitted, with work and to varying degrees of gain.. but nothing in the engine itself.
#4 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,182 posts
  • East Coast
Posted 25 October 2007 - 11:53 AM
i think the similarity resides only in the PCV valves - they are identical between the two, nothing else is compatible at all. the only related idea is that they are interchangeable FITMENT WISE only, in other words you can exchange engines relatively easily since the motor mounts are nearly identical in spacing and such but the electronics and everything else is a nightmare.
a humorous analogy would be to say it's the same reason you can't find anything on "how similar are 350 V8's and EA series engines?".
#5 Numbchux
Numbchux
    EJ conversion addict
  • 6,719 posts
  • Saginaw, MN
Posted 25 October 2007 - 12:18 PM
the different engine code is a pretty dead giveaway.
EJ stuff is interchangeable between other EJ engines
btw, SOHC EJ engines have the spark plugs in virtually the exact same place as the EA's.
#6 mellow65
mellow65
    Subaru, my drug of choice
  • 1,086 posts
  • Portland
Posted 25 October 2007 - 05:03 PM
the flywheel bolts are the same and i think the throw out bearing is too, so there you go that's three things
