Valve cover gasket leak
7 replies to this topic
#1 sidekickin
sidekickin
    USMB Regular
  • PipPipPip
  • 120 posts
  • Southwest Ohio
Posted 14 November 2007 - 08:31 PM
Hey all,
Got an oil leak at the valve cover gasket on my EA-81 hatch. It isn't real bad yet, but I would like to take care of the problem before it gets worse. Has anyone used high-temp Permatex on the valve cover gasket to fix the leak? Wasn't sure how well this would work on a gasket that is likely saturated with oil. Thanks for your help...
#2 nipper
nipper
    Semi Elite Master of the
  • 17,105 posts
  • Long Island NY
Posted 14 November 2007 - 08:45 PM
Just try tightening the bolts first.
nipper
#3 sidekickin
sidekickin
    USMB Regular
  • PipPipPip
  • 120 posts
  • Southwest Ohio
Posted 14 November 2007 - 08:52 PM
I tried tightening the bolts when I first discovered the leak, but it didn't fix the problem...
#4 nipper
nipper
  • 17,105 posts
  • Long Island NY
Posted 14 November 2007 - 08:53 PM
Your best solution is just another set of valve cover gaskets.
nipper
#5 grossgary
grossgary
    Elite Master of the Subaru
  • Gold Subscribers
  • 17,900 posts
  • West VA
Posted 14 November 2007 - 09:02 PM
best bet is to get a valve cover gasket set. the ones that come with new grommets are nice. the grommets can leak as well, best to replace them while you're in there. they are $2.00+ EACH from Subaru, best to get a kit that has the gaskets and grommets (i think Fel-Pro usually has it all).
i would not use sealant on the valve cover gaskets, it might work, but if it doesn't it's annoying to clean up out of the grooves...oh i'm speaking from EA82 experience the EA81 may differ with the groove? another problem with old valve cover gaskets is they easily break, i would not consider a used one a very good base to cover with sealant.
#6 GeneralDisorder
GeneralDisorder
  • 20,278 posts
  • Portland
Posted 14 November 2007 - 09:50 PM
Get a new set of cork valve cover gaskets. BUT you should coat both sides of the gasket in a thin layer of Ultra Grey RTV and let it dry before installing them. Replace the rubber bolt washers too. This will prevent the gaskets from soaking up oil and getting cooked.
#7 GeneralDisorder
GeneralDisorder
  • 20,278 posts
  • Portland
Posted 14 November 2007 - 09:53 PM
EA81 gaskets are cork, and the valve covers are steel. There is no groove at all. It's completely unlike any later engine design being that they are not overhead cam.
Think of them as a smaller, but thicker version of the oil pan gasket, but without the bolt holes.
#8 grossgary
grossgary
  • Gold Subscribers
  • 17,900 posts
  • West VA
Posted 15 November 2007 - 07:59 AM
bingo, thanks.
