my a/c wont engage
14 replies to this topic
#1 seanski06
seanski06
    User Awaiting Email Confirmation
  • 442 posts
  • carbon county
Posted 20 November 2007 - 11:53 AM
i checked all my fuses and relays.....i dont really have any schematics for the wiring
its a 99rs, the only way i can get it to engage is if i pull the relay out of the fusebox, and connect two of the plugs with a jumper wire
i would love to have a detailed discussion about this lol
-sean
#2 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 20 November 2007 - 11:57 AM
This is easy.
You have a leak. You have to take it someplace and have the leak repaired. Don't jump the pressure switch as you will damage the compressor.
nipper
#3 seanski06
seanski06
  • 442 posts
  • carbon county
Posted 20 November 2007 - 12:00 PM
would the same thing happen if it wasnt recharged?
i could do the recharge myself, but if its def. a leak then i'll have to fork over some doe
#4 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 20 November 2007 - 12:05 PM
:confused:
#5 seanski06
seanski06
  • 442 posts
  • carbon county
Posted 20 November 2007 - 12:09 PM
in other words, would i be able to solve it with a couple cans of refrigerant
#6 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 20 November 2007 - 12:15 PM
Yes, maybe, but for how long, a day, a month, a year?
Also how long have you had this problem. If its recent the system may not be contaminated. If its been a month or more it may need to be evacuated to get the moisture out.
nipper
#7 seanski06
seanski06
  • 442 posts
  • carbon county
Posted 20 November 2007 - 12:18 PM
it didnt work when i bought the car, that was sometime in the summer..i never cared cuz i could put the sunroof back but i figured its time to get it fixed now lol
#8 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 20 November 2007 - 12:20 PM
Take it to a shop then and have it done properly. You can try and do it yourself, but if it doesnt take you just waisted money on refrigerant. Most likely its a bad O ring someplace, and by now some moisture in the system.
nipper
#9 seanski06
seanski06
  • 442 posts
  • carbon county
Posted 20 November 2007 - 12:22 PM
appreciate the help
they should just make a seperate section of usmb where people could ask u questions and then donate a small fee...(get rich quick, work from your own home)
#10 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 20 November 2007 - 12:23 PM
appreciate the help
hehehe, nah i enjoy the teaching part :)
nipper
#11 ericem
ericem
    First Gen Legacy Master
  • 2,477 posts
  • CANADA Maple,ON
Posted 20 November 2007 - 05:58 PM
that is a good idea eh xD. Hey nipper is it possible to rebuild the o-rings on the a/c compressor? I am thinking with mine the shaft o-rings are definitely worn.
#12 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 20 November 2007 - 07:04 PM
If you can find the parts, yes they are rebuildable. They are actually fairly straight forward. Sometimes though the shaft seal is wiped out because the seal has worn a ridge in the shaft.
You know the old saying, you can't make it any worse then it already is, so go ahead and take it apart.
nipper
#13 Rooster2
Rooster2
    Subaru Master
  • 4,706 posts
  • Indianapolis
Posted 20 November 2007 - 09:23 PM
What I would suggest is buying a couple cans of 134a refrigerant, and an installation hose, if you don't have one. It is also a good idea to buy a can of 134a with leak detector. Once installed, use a black light to see where the refrigerant is leaking out.
Don't know if Subie is one, but some cars have a temperature sensor that prevents the compressor from turning on if the outside temp is lower then about 56 degrees. I know VWs have this feature. You may want to find out if Subies have this feature.
I think all cars A/C systems are now made, so if the system has a refrigerant leak, the A/C compressor will not turn on if the refrigerant level is too low. So, I suggest adding one can of 134a to see if the compressor to see if the compressor will turn on. If so, add the leak detector to find the leak. If you can't find a leak, then fully recharge the system. If there is only a small leak, then I don't even think about tearing into the system to find an "O" ring leak. That is way too much work for not much gain. I have one old car that I add a can or two of 134a over a summer to keep the A/C pumping out cold air. Paying only about $15 for cool air over a summer season is the route that I take.
#14 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 20 November 2007 - 09:27 PM
It really depends upon how green you are if you want to have an easily fixable leak. If he takes it to a shop, they will find the leak and fix it.
Personally i am so against anyone who does not have a set of gauges, with an ac system that has been dead for months, just throwing a few cans of refrigerant into an ac system.
If he wants to try it fine, but i reserve the right for an "i told you so" if he cant get it to blow cold enough :clap:
nipper
#15 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 20 November 2007 - 09:32 PM
+1 or find maybe a local guy who does hvac he has the guages you need and a recovery tank and a vacuum, and can get the refrigerant.
