torxxx Posted December 13, 2003 Share Posted December 13, 2003 ALright guys, I'm tired of the lame yellow dash lights and I'm going to switch to a diff color.. Guess my main question is are hte dash lights the same bulbs as the reading lights that are above the rear view mirrow? And also, I've never pulled my dash apart. How complicated is it? And is it something that I can do in a few hours? A response will be greatly appreciated. thanks guys Quote Link to comment Share on other sites More sharing options...
ru4x4ever Posted December 14, 2003 Share Posted December 14, 2003 IN my 80 i was able to remove my gage cluster in the parking lot of a pull it yard in about 10 min. there are a few screws around the dash trim once you have the dash trim off there should be 4 screws holding cluster in. remove those then should be loose. The speedo cable and wire harness will be attached , eather pull on cluster till you pull enough out to un hook said attachments or go under the dashand reach to find back of gage cluster and unhook that way. There is enough slack to pull out when you just grab cluster. Then remove bulb, i think that the bulb is clear and dash backing is the color , it was that way for my roo. Hope this helps:headbang: Sean Quote Link to comment Share on other sites More sharing options...
sparkster58 Posted February 10, 2007 Share Posted February 10, 2007 ok...my Dash lights in the H2* are going out fast i need to replace them.... iam all thumbs as everybody in seattle area knows... is there anybody out there that wants to make a few bucks changin my dash lights????????? spark * 93 leg " L" wagon: Quote Link to comment Share on other sites More sharing options...
