Anyone know the procedure to adjust the choke?
There is a thing called a choke-pull off assy. This opens the choke as soon as the car starts to allow some air in. Its a little vac diaphram attached to the chike plate.
Check to make sure its working.
Choke adjust is very easy. When the car is cold, adjust the choke plate so that it just closes. Usually if anything is wrong its the CPA.
nipper
nipper
i screwed with the choke settings earlier, so i think i need to set it properly.
