bushbasher Posted December 14, 2003 Share Posted December 14, 2003 My seat fabric has become full of a kind of fine dusty clayish dirt, the vacuum got some of it, but does anyone else have a method of getting this stuff out? Any good products to try? It's dry and not really "ground in" so I figure it shouldn't be too much of a struggle. Quote Link to comment Share on other sites More sharing options...
GLCraig Posted December 14, 2003 Share Posted December 14, 2003 Compressed air and a dry stiff brush will loosen more of it up so you can vacuum it up. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 14, 2003 Share Posted December 14, 2003 a carpet cleaner with the little apholstery (sp?) attachment on it should work or you could redneck it and break the pressure washer out:banana: Quote Link to comment Share on other sites More sharing options...
trooperjeep Posted December 14, 2003 Share Posted December 14, 2003 Use an old stiff tooth brush to loosen the dirt and a powerful shop vac to pull it out of the fibers. T.J. Quote Link to comment Share on other sites More sharing options...
WagonsOnly Posted December 15, 2003 Share Posted December 15, 2003 If you have the time on your hands, a stiff toothbrush and some aerosol upholstery cleaner should solve the problem. I use Bissell spray-on upholstery and foaming carpet cleaners (2 different products), available wherever Bissell vacuum cleaners are sold. If you want to speed things up a bit, you could try a stiff nylon brush on a paint buffer at low speed. Quote Link to comment Share on other sites More sharing options...
Stupidru Posted December 15, 2003 Share Posted December 15, 2003 oxi-clean...but its a very long process. Drenched seats with oxi-clean, then scrubed and let dry for about 6 months (no SH*T). Eventually the dirt turn to dust & I was able to dry brush it out. My seats were severly mildewed when I purchased car, now they look half decent. Quote Link to comment Share on other sites More sharing options...
