rear disc backing plate
6 replies to this topic
#1 junkyardgabe
junkyardgabe
    WRX Goal Accomplished!
  • 558 posts
  • Lisbon Falls
Posted 14 December 2003 - 08:26 PM
i just picked up a rear disc set up off of a 88 gl10 turbo 4x4 sw and the backing plates were rotten. can i use the backing plates off of a 2wd xt6
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,694 posts
  • Portland
Posted 14 December 2003 - 08:48 PM
XT6 is completely different - my bet would be no.
#3 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 15 December 2003 - 12:46 AM
read this explaining the differences
http://www.warpthree...e/Rear Disc.htm
#4 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 15 December 2003 - 01:30 AM
hey miles. you might add that the "modification" necessary to the 2WD backing plate is simply an enlargement of the center.. not hard to do; i know as Skeet's 4WD wagon has 2WD backing plates on it thanks to yours truly.
I'm liking your tech writeups more and more; "someone had to do it!"
#5 Subarutex
Subarutex
    Oldschool Show Queen
  • Moderator
  • 2,551 posts
  • Mountlake Terrace
Posted 15 December 2003 - 01:37 AM
My 5 lug converted RX is sporting 2wd xt6 backing plates in the rear. You have to make the center hole bigger by just about a 1/4 inch all the way around.
#6 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 15 December 2003 - 01:55 AM
the job is made much easier by that middle part being made of aluminum!
#7 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 15 December 2003 - 03:42 AM
check out this clossary page
http://www.warpthree...ce/Glossary.htm
each term explains what it came with, this will make good info for mix and match...
