swilde20 Posted December 28, 2007 Share Posted December 28, 2007 i bought a set of projection headlights from a 97 outback and was wondering if anyone could tell me what i needed to do convert the wiring? stock has 3 wires and the projections have 4. thanks steve Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted January 2, 2008 Share Posted January 2, 2008 The projection lights should have separate bulbs for low & high beam. Projector for low & normal for high beam. Where do the 4 wires come from? Do two go to the projector & two to the high beam? Quote Link to comment Share on other sites More sharing options...
swilde20 Posted January 3, 2008 Author Share Posted January 3, 2008 all 4 come out of 1 connector, then there is wires going to the 3 different bulbs. thanks steve The projection lights should have separate bulbs for low & high beam. Projector for low & normal for high beam. Where do the 4 wires come from? Do two go to the projector & two to the high beam? Quote Link to comment Share on other sites More sharing options...
Frank B Posted January 3, 2008 Share Posted January 3, 2008 Got any pics? Sounds like one is a shared ground, the other three are to supply voltage to each lamp. Quote Link to comment Share on other sites More sharing options...
Skip Posted January 3, 2008 Share Posted January 3, 2008 Thia was covered a few eeks ago I hope you will find what you need. It's long but does have links to the pictures you need http://www.ultimatesubaru.org/forum/showthread.php?t=83032&highlight=projector Quote Link to comment Share on other sites More sharing options...
