Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
tranny swapping
#1
Posted 15 December 2003 - 03:30 PM
flywheel and clutch parts
the tranny itself
what axles do I use?
the linkages and stuff
the drive shaft (I'm going to get a one piece one made up)
#2
Posted 15 December 2003 - 04:06 PM
You also need the 3.7 rear end, as your hatch is a 3.9.
#3
Posted 15 December 2003 - 04:18 PM
i can fit a 25spline doj onto a 2wd axle, but it has a lot of play. it works for a get me by, but i dont recommed running with it
other than that, swapping rx tranny is the same as 5spd. but you will have to figure out the diff lock system
I am assuming the RX has 23 splines in the rear
you can also do the ea82 front lower control arm if you want to use ea82 axles, like in my trashwagon5 and rguyver's hatch
#4
Posted 15 December 2003 - 04:47 PM
#5
Posted 15 December 2003 - 04:57 PM
so then he will have to either shorten a 25spline ea82 turbo axle, or have the ea82 front suspension conversion
#6
Posted 15 December 2003 - 05:14 PM
The EA82 swap would be intersting, but what does it buy you? Probably easier for you to get JY axles and parts eh Miles?
#7
Posted 15 December 2003 - 05:28 PM
suppose if there is a pair of complete ea82 struts with ea82 control arms, for cheap or already available, i would say its woth the time on a serious projact
and also having ea82 front suspensin will give you bigger brakes and suspension travel
it will also afford the option of using XT6 suspension on an ea81 body, and with the rx tranny
#8
Posted 15 December 2003 - 09:51 PM
#9
Posted 15 December 2003 - 10:13 PM
Are you intending to off-road this car? If so forget the RX tranny. The Lo range is only 1.2:1 as opposed to the normal Lo range in a D/R tranny of 1.45:1 - couple that with it's 3.7 diff, and it makes for a useless off-road tranny (no crawl ratio at all to speak of).
To get the 5 lug, you would have to swap out to an EA82 style suspension (has it's own problems such as alignment [you ever get yours right Miles?], and some custom fabrication - welding the control arm mounts to the cross-member, etc...), and then swap over to the XT6 suspension which is yet another modification on top of the EA82 swap, and I'm sure would have it's own pile of problems with the EA81 car... never heard of anyone doing it, but it would be cool.... just a lot of work to get it on, and to get it right (ie - proper alignment).
#10
Posted 15 December 2003 - 10:59 PM
yeah we fixed it at lumpy cam's. we used the fresh ea81 inner tie rod (we lengthened) from ed and and used the ea81 tie rod end.
but we had to ream the knuckle on the ea82 knuckle to fit the ea81 tie rods. i originally had ea82 outer tie rod on the way out.
but that was not the problem
the problem was my rack was not centered when i did the mod. she is all good to go making the trip back east ("out midwest")
so here it is
You have to take the rear portion of the ea82 mount (the 2 flanges the lower contol arm bolts thru) cut ott the rear one by grinding the welds and taking the piece off as its stamped on
fit that BEHIND the lower control arm mount on the ea81 crossmember. thread a bolt thriu and weld on the mount (it will fit the contour of the crossmember) there will be extra metal on one end, so you can cut that off before you mount it
the strut brace rod will fit , but only with the new mount. the ea81 lower control arm will fit in the ea81 mount, but the axle will be too far forward and rub the frame, and hyper extend enough to rip the boots or pop them off. and the strut brace will need modified
so make the mount and put on the ea82 control arm, strut rod fits.
I used the EA82 struts, knuckle, and brakes, so i did not have to modify the ball joint hole. i made my mod with the ability to use unmodified replacement parts
i used a spring compressor to remove thestrut cap
I used a EA81 strut cap, with the hole modified to fit the ea82 strut shaft and nut. i drilled a straight hole, but i should have made the half moon shape to keep the struts still while the nut is tightened
i used part of the ea81 shaft bushing to lengthen the ea82 strut bushing, and ea82 springs and plastic boot. i cut the ea81 bushings to use the fat part
so now i can have an ea82 strut that fits on the ea82 strut tower, and the ea82 control arm to fit the axle
i had to lengthen my tie rods because i had a manual rack. The MOD was supposed to use ea82 inner and outer tie rods, to fit on the ea82 POWER rack.
i recommend using ea82 struts and tie rod ends.
if you use an ea82 strut and knuckle, you will have to drill the holes out for the ea82 tie rod end and the ball joint hole on the new control arm
dam, i should do my write-up while i m on a roll !
does any one have pics of crossmembers, control arms, or struts i can use?
so now my mods will accept an xt6 lower control arm, and knuckle. i will swap my modified EA81 strut cap to the xt6/impreza/legacy struts
i have the idea of using the ea82 swaybar brackets and put them on ea81, they swaybars will bolt to the new lower control arms
that way i can take off the ea81 swaybar to make room for dual exhaust
#11
Posted 15 December 2003 - 11:16 PM
#12
Posted 15 December 2003 - 11:20 PM
but RX low is still tall enough to drave around on, you just use more gas cause youre ROMPIN' it!
myoss feece take the RX to 75 in lo-range on the hiway
#14
Posted 16 December 2003 - 06:54 AM
RX tranny is 25 spline, as are all turbo EA82 trannys. EA81 axles are 23 spline.... except some have been found that are 25 spline, but it is not clear what these came from, as the general consensus seems to be that the EA81T cars had 23 spline just like regular EA81's...
No one knows definatively what car a person would look for to find 25 spline EA81 axles.... in fact it may be that they never existed beyond a custom build from some axle shop. The only set I know of (or indeed, that anyone knows of from what I can tell), is a set that Mudrat79 pulled from an EA81 Turbo coupe. But other turbo coupes of the same vintage have been examined (with matching numbers on their tranny, so they were factory), and found to not be 25 spline. Very weird, and it's probably best to just have a set made.
#15
Posted 16 December 2003 - 01:30 PM
#16
Posted 17 December 2003 - 12:50 PM
tranny, rear diff
25 spline EA-81 axles (from cvaxles.com unless I score on the board)
ok two more questions can I get my flywheel re-drilled for the EA-82t PP? that way keep my TDC marking and stuff?
#17
Posted 17 December 2003 - 07:57 PM
#18
Posted 18 December 2003 - 10:03 PM
