'74 vacuum advance question
8 replies to this topic
#1 RatInDaHat
RatInDaHat
    USMB Regular
  • PipPipPip
  • 71 posts
Posted 10 January 2008 - 03:27 PM
Ok, so i have a quick question from any of you '74 1400 owners.
Should the vacuum advance hose be running from the manifold or the carb? That's all i need to know.
Thanks,
-Dusty-
#2 hatchsub
hatchsub
    Currently Subaru-less :(
  • 2,714 posts
  • Guilford
Posted 10 January 2008 - 03:51 PM
Um i dont own a 74 but i kno for sure that you want it run off the carb. If you were to hook it to manifold vacuum then the advance would be advancing at idle. When hooked to the carb when u step your foot on the gas it pulls the advance open with the amount of throttle you apply.
#3 RatInDaHat
RatInDaHat
    USMB Regular
  • PipPipPip
  • 71 posts
Posted 10 January 2008 - 03:58 PM
The reason i ask is that it has been hooked to the manifold since i bought the car, and i've never been able to get it to idle right.
I swapped it to the carb and it seems to be doing better now. Just figured i would ask some of you guys.
#4 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 10 January 2008 - 04:25 PM
Yea with it hooked to your manifold vacuum your timing was way advanced even at idle so i would imagine your car would idle like crap up until the point in the rpm range where it would be pulled open normally. Now that you have it hooked to the carb i would go back and check your base timing to make sure its set right. EA81s are supposed to be set at 8 degrees. Not sure what a 74 suby would be.
#5 RatInDaHat
RatInDaHat
    USMB Regular
  • PipPipPip
  • 71 posts
Posted 10 January 2008 - 04:30 PM
Manual says 8°, but since i'm at 5200 feet in elevation i have it set at 10.
I set it with the vacuum line plugged, so it should still be correct, but i'll double check it when i get a chance.
#6 Leeroy
Leeroy
    Old boxer tricks!
  • 648 posts
  • Albury, NSW, Australia
Posted 11 January 2008 - 05:34 AM
Thanks,
-Dusty-
Just checked my 74 coupe and the vacuum advance hose connects to the carb.
#7 RatInDaHat
RatInDaHat
    USMB Regular
  • PipPipPip
  • 71 posts
Posted 11 January 2008 - 11:26 AM
cool. thanks.
so new question.
I converted it to a manual choke because i was having issues with the automatic one.
Some times, when warm, i can open it all the way and it will idle and run with no problems. Other times i can't open it more than half way or it will die. Any ideas?
-Dusty-
#8 moosens
moosens
    Vintage Subathusiast
  • 1,963 posts
  • Bridgeport CT
Posted 15 January 2008 - 12:14 PM
OK,pretty soon I'll be right there with you.
.....just got into town on Saturday night ;)
Posted Image
Skip,I'm sorry about the photo size.
She should clean up real nice. Will run but isn't drawing up from the tank so I need to drop it,drain it,treat it,and go from there. Ran pretty good,no smoke,no real bad noises,with some gas down the carb.
I'll try to get a hold of whatever '74 stuff my buddy Charlie has,if any is left. Weird year,spare tire down under. Please check my new list on needs and I'll be working on stuff for you too.
Cheers,
Paul
#9 RatInDaHat
RatInDaHat
    USMB Regular
  • PipPipPip
  • 71 posts
Posted 15 January 2008 - 12:16 PM
nice looking car there.
I just wish i could figure all of this old mechanical stuff out.
