98 2.5 water pump question
i am installing a new water pump on my 98 2.5, my question is, I am reusing the plastic curve pipe thingy under the water pump, and when I tighten it on my new water pump, there is a gap (around 1/8") in the center of it, away from the two bolts. where as the contact area directly under the 2 bolts has a good seal.
it seems the plastic pipe thingy is warped in the center, is this normal? I have checked the rubber seal for the thermostat and its not being caught in the center.
Thanks!
