Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Cold Weather
#1
Posted 21 January 2008 - 06:27 PM
#2
Posted 21 January 2008 - 07:28 PM
#3
Posted 21 January 2008 - 08:15 PM
nipper
#4
Posted 21 January 2008 - 08:43 PM
below +30f, the seat is stiff
radiator split seam at -4f
#5
Posted 21 January 2008 - 09:04 PM
-Doug
#6
Posted 21 January 2008 - 11:02 PM
anybody else have rigs with these cold weather oddities?
Speedo cables make funny noises, as you mentioned.
The locks get stiff - varies - one I can almost not unlock, other is only "gummy" feeling. Sometimes the door gaskets get frozen to the door & glass.
Before switching to synthetic ATF, the 3ATs shift wierd.
My 87 4spd was so stiff that on the first shift from 1 to 2, it would slow almost to the point of wanting to stay in 1 - until I put synthetic gear lube in it.
On the starting stuff:
A good / new battery has about 1/4 of it's capacity at 0 degrees VS 70 degrees.
Under ideal conditions (not found in cars), a lead acid battery is near end of life (about 80% of original capacity) after 5 years.
And the starter needs a lot more current to turn the engine w/ thick oil.
#7
Posted 22 January 2008 - 03:27 AM
..but the last time I smirked about living in Paradise to you poor winterbound folks, I got hit with a 34 degree cold front and it HURT.
So I'll abstain from being a wise-rump roast.
#8
Posted 22 January 2008 - 03:49 AM
#9
Posted 22 January 2008 - 04:39 AM
Went ice fishing this last weekend with single digit temps..
-Doug
We still had open water on 3 of the small lakes near me this past Saturday. Didn't look at Baw Beese Lake, it's a fairly good size lake.
The '85 doesn't get driven that much, so I can't really say how the cold bothers it but it is cold blooded, and doesn't like to start if temp gets below 35*..
The '86 likes to do the spit,sputter,cough,choke,gag,puke thing when 1st started if temps are below 30*.
Altenator likes to sing for a few minutes if temps get below 25*.
Engine runs to cold for any real heat out of the heater when temps get below 25* too. I can watch the T-stat open/close by looking at the temp gauge while driving down the road at 55 MPH. It has a newish radiator, heater core, and Subaru T-stat. Running around town the heat is good, but get over 45 MPH, and the engine cools down.
#10
Posted 22 January 2008 - 06:27 AM
Speedo cable noisy
Fuel pump relay sticks over night (have to heat the interior for about 10 minutes with a heater)
Circuit board on TCU must be going bad, shows fault when cold, after I heat the interior it's ok.
Door locks, and trunk lock, flakey
Car creaks, and moans, when driven (like every Japanese car I ever owned when operated at -20, or colder).
Of course, no high gear when cold, I'm told its "normal".
'91 Legacy Sport Sedan 325,000 miles
#11
Posted 22 January 2008 - 07:35 AM
Awesome, to each his own. Sounds like the Soobie just needs her own coffee of sorts.winterbound by choice, my friend. hard to snowboard and mountainbike, without, well mountains. i love snow and cold weather. my loyale on the other hand..... takes her a little time to wake up on these cold mornings.
I get to deal with air so humid you can walk through it, and mosquitoes, and the incessant influx of people who didn't get along with anyone where they came from. Florida seems like a great place to move to when you have no motivation to go anywhere specific, and we get alot of what I call "the B-Ark Crew" down here.
SO, we each have our slice of Paradise, and pay our tolls.
/threadjack off, mouth shut.
#12
Posted 22 January 2008 - 08:09 AM
You did what???
My buddy has a cottage near Houghton Lake. There was 6-8" of ice there and the surrounding areas. At least the sun was out so I'm sure it felt a couple of degrees warmer than it really was!
#13
Posted 22 January 2008 - 06:27 PM
#14
Posted 22 January 2008 - 11:26 PM
#15
Posted 22 January 2008 - 11:53 PM
92 Loyale 4wd EA82 5 speed wagon. Minus 20 C (about 2 below for you Luddites) this morning. IAC decides to take the day off, cranking speed is sluggish, block heater doesn't have a plug on it, it starts but I gotta feather the gas for 5 minutes or so before I get a steady 1200 RPM fast idle, by now the w/shield is frosty inside,still haven't gotten the cooling system to where there's any heat on a cool day, let alone this morning, can't use the left rear door cause the weatherstripping has torn out of the door bottom from being frozen to the body, not a chance I'll lock any door or t/gate until spring, tires were square, rear brakes groaned and struts were solid as I pulled out of the drive, forget shifting for another 2 blocks, clock only works after 1 hour of fullbore heater, and I don't even live in a really cold place like Missoula, but I love my Subaru!!
heh.. sounds like fun.... actually, missoula doesnt usually get this cold. we have a couple bouts of arctic air fun every winter, but it's normally pretty mild. nothing like my days of living back in the upper peninsula of michigan. now that was winter.
#16
Posted 23 January 2008 - 03:34 PM
