Guest sonnyny Posted July 12, 2003 Share Posted July 12, 2003 I have a 96' 2.5 leg. GT. Started it up cold and it sputtered like it was starving for gas or weak spark for about 5 seconds then rev<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/ohwell.gif ALT=":\"> ed @ 2,000 rpms for another 5. Then it kicked down to a normal idle speed. Plugs, wires, fuel filter, air filter all look good. Would like to hear your ideas. Quote Link to comment Share on other sites More sharing options...
Guest 97SubaruGT Posted July 13, 2003 Share Posted July 13, 2003 Could be a separated vacuum line. If it does not happen again, I wouldn't worry about it. ECU probably compensated for the low idle and kicked it up to 2000 rpm for a few secs. Quote Link to comment Share on other sites More sharing options...
Guest sonnyny Posted July 13, 2003 Share Posted July 13, 2003 It is now 3 days later and same symptoms are reoccurring. I cant find any vacuum leeks or seperated hoses. Once again, the car runs superb after about 15 to 30 seconds. I would appreciate a bit more of your superior knowledge. Quote Link to comment Share on other sites More sharing options...
Guest rcoaster Posted July 14, 2003 Share Posted July 14, 2003 It might be that the Idle Air Control valve might be going bad. Try this, when starting up the car and it is sputtering, trying to run smoothly, press the accellerator slightly. Does the car rev up and run smoothly? Let go of the accellerator. Does the car start sputtering again? If so, then it is definitely the IAC. It might not be working right when the engine is cold, but once it warms up, it starts to work right. I think that might be the problem. Quote Link to comment Share on other sites More sharing options...
Guest kevinsUBARU Posted July 14, 2003 Share Posted July 14, 2003 engine light? Yes? Maybe cam/crank sensor Quote Link to comment Share on other sites More sharing options...
Guest sonnyny Posted July 15, 2003 Share Posted July 15, 2003 Kevin, now you have me thinking. The engine light isn't on but I know there is a leaking cam or crank seal. Haven't pulled the timing cover off yet to see. Maybe oil leak is fouling a sensor? <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/grin.gif ALT=" >D"> Quote Link to comment Share on other sites More sharing options...
