Cluch, 2WD-vs-4WD
Originally posted by archemitis
but the problem is that the 2x has its own spline(output shaft on the tranny), and you cant put a 2x on a 4x, or vise versa.
you got one for free or something?
i can send you a used 4x reely cheap.
Acording to the parts store:rolleyes: ,2WD and 4WD are the same spline count/shaft dia. But the 4WD disc is 1" bigger, and $30 more:eek: This is just for my DD so it's no pwer house that needs all the cluch it can get. The cluch will slip if I floor it in any gear @ any speed right now:-p So I need a cheep fix.
How much U want for your used one, and how much is left on it?
yah, i think ea81 are the same spline. but ea82s are different, i know for sure. the big one only comes with the 1 spline count, and the the little ones come in both i guess. but the diameter of the outside is different.
if you want to use a small clutch you would need a small flywheel, theres not an inch more surface area around the friction part. the clutch would sit half way on the pressure plate, and halfway off.
5 bucks plus shipping, the rivits are still pretty far down there, but you never know. check out the parts bin. thats where i found mine the cheapest about 1 month ago, for just the friction plate.
