Throttle cable very slack at 1300 idle
ea82 '91 loyale 4wd 5spd TBI
I've looked for vacuum leaks everywhere and replaced all vacuum hose. No change. Cleaned up the IAC with BrakeKlean. No change. Checked the IAC assembly with 12V and some jumper wires. Seems to work just fine.
Freakin' idle is still 1300 when warm. Temp guage never climbs aboce the "C".
Also, at idle, the throttle cable is very slack. At least an inch of pedal travel before throttle is pulled back. Is this normal?
Kalo
  • 2 years later...
