sloppy ea82 shifter
7 replies to this topic
#1 Rooinater
Rooinater
    Official Thread Killer...
  • 2,285 posts
  • Gig Harbor
Posted 05 February 2008 - 09:57 PM
i was wondering if anyone new of an easy fix for a sloppy ea82 shifter, it seems to have excess swing and play. i remember a long while ago there used to be a sloppy shifter fix for one of the d/r trannys. but can't remember for the life of me. i was wondering if anyone would point me in the right direction. thanks
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,641 posts
  • Portland
Posted 05 February 2008 - 10:23 PM
On the 5 speed's it's generally just needing new bushings. It's like $30 for all the bushings. Just a bunch of nylon getting old and worn....
#3 Rooinater
Rooinater
  • 2,285 posts
  • Gig Harbor
Posted 05 February 2008 - 10:30 PM
sweet, i'll have to look into that, so all the bushings on the arms. i'll have to go to subaru directly for that, right?
#4 GeneralDisorder
GeneralDisorder
  • 21,641 posts
  • Portland
Posted 05 February 2008 - 10:36 PM
Yeah - sadly they are dealer only parts. But at least they are inexpensive. Check that the bolts aren't worn out, or anything else badly worn. It's usually just the bushings though.
On the flip-side, you could always snag a linkage from the yard that feels better, and either just use it, or install the bushings on the spare and just slip it right in. It's only like 6 bolts, a cotter pin, and the interior consoles.
#5 Rooinater
Rooinater
  • 2,285 posts
  • Gig Harbor
Posted 05 February 2008 - 10:58 PM
worn bolts... ok, i'll take a look later this week, hopefully it's just some bushings. i'll just see how much new ones are first. my shifting rod is custom bent to clear all the divorced case stuff; so i have to at least keep the shifter.
#6 Numbchux
Numbchux
    EJ conversion addict
  • 6,813 posts
  • Saginaw, MN
Posted 05 February 2008 - 11:29 PM
I stumbled across a pretty sweet fix this fall. when I went to put everything together, I couldn't find the 2 bushings for one of the pivot points on the tranny side. but I did have the bolt and the sleeve that fits over it. so I wrapped the sleeve with electrical tape until it fit snugly into the linkage. I had only intended it to be a temporary fix, but it improved shifter feel soooo much, I've left it. and it's worked great! and again, I only did it to one pivot point!
#7 Rooinater
Rooinater
  • 2,285 posts
  • Gig Harbor
Posted 06 February 2008 - 12:47 PM
i'll keep that in mind if I can't find the parts. all ideas are welcome. the shifter won't go into reverse in double low, cause of the shifter swinging so much and interfering with my nissan tcase shifter. so I can't quickly rock forward and reverse in the mud or snow. which poses a problem in washington, wasn't a problem in az, just a nusance.
#8 zukiru
zukiru
    EJ22T
  • 1,229 posts
  • Oak Grove, AL
Posted 23 April 2008 - 01:26 AM
god, found this on search.....
and had to add
If you can't Duck it,
you know the rest!
