ru4x4ever Posted December 19, 2003 Share Posted December 19, 2003 My suspension is adjusted all the way up already, if i put these 14" 's on with 26's how much triming will i have to do? Will it be worth it? anybody know? Sean:confused: Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 19, 2003 Share Posted December 19, 2003 A considerable amount - also having the suspension adjusted up like that makes it stiffer, and you don't get as much travel. You CAN mount them tho - it just requires a whole lot of trimming. You won't have much left for fenders really. You consider a lift? It would accomidate 26's without any trimming if you go that route. GD Quote Link to comment Share on other sites More sharing options...
ru4x4ever Posted December 19, 2003 Author Share Posted December 19, 2003 Lift? Yeah but not sure if i can do what $325 or so is the cheapest i have found. On somebody's link page Quote Link to comment Share on other sites More sharing options...
Qman Posted December 19, 2003 Share Posted December 19, 2003 Are you using Pugs or something else? the 26's themselves won't require much trimming. It depends solely on which wheels you use. How does your ladder mount to the car? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 19, 2003 Share Posted December 19, 2003 Ah - yes - Qman has a good point - your offset is going to dictate how much you'll be trimming - the larger the negative offset and the width of the rim, the more you'll have to trim... GD Quote Link to comment Share on other sites More sharing options...
Rooinater Posted December 19, 2003 Share Posted December 19, 2003 i did a article a long while ago on trimming the fenders. i re made it and put it on my new site under subaru modifications. but yes if you are using pug wheels. you should be fine with 26" tall tires. http://www.westcoaststompers.com/mods/mods.htm that should be the right link but if not go to west coast stompers main page. on the link bar go to subaru modifications. Quote Link to comment Share on other sites More sharing options...
ru4x4ever Posted December 19, 2003 Author Share Posted December 19, 2003 Qman, my ladder is bolted to my top rack then it goes in to wheel- well and goes up about 2" then has a formed piece of metal that is screwed in 4 places to this lip that is in wheel-well. Its sturdy as hell, my buddy rode on it FIREMAN style one day ripping down anm old fire road. We have done the jump hold test to see how tuff it was when we got it done. I think in my pics it has a view of the top bolting? Sean Quote Link to comment Share on other sites More sharing options...
Qman Posted December 19, 2003 Share Posted December 19, 2003 The reason I asked about the ladder was how much room it took in the wheel well. You may or may not have issues with it and the larger tires. Mostly when the suspension is compressed. Cool set up. Quote Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted December 21, 2003 Share Posted December 21, 2003 so, with a little trimming, i can fit in some 26-27" tires? am i reading this correctly? this would work great for my very limited budget. this way, i can at least get the clearance that i need. of course it won't look half as beasty as a lifted soob, but i can always do that down the road or when i upgrade to a better car. i want to get an xt6 that is for sale, but i think my next car will be a gl-10 sedan w/a turbo. hopefully Quote Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted December 21, 2003 Share Posted December 21, 2003 would it be better to use toyota or chevy rims to accomidate some 26-27" rubber w/o a lift. i just cant wait to get that much needed clearance. plus with the money i'll save from the lift, i can get a winch. Quote Link to comment Share on other sites More sharing options...
Qman Posted December 21, 2003 Share Posted December 21, 2003 First, without the lift it will require more trimming. The best fitment is with steel pugs. A lift and a come-a-long will go a looooooong way. Quote Link to comment Share on other sites More sharing options...
Rossta86 Posted December 21, 2003 Share Posted December 21, 2003 I am skeptical about putting 26 or 27 inch tires on with out a lift. I run 27.7 inch tires on yota rims with a 3 inch lift and i had to do some fender cutting, but a lot of beating inside on the wheel well. I could be wrong but i don't think u can get away with putting 26 or 27 inch tires on your unlifted soob without and fender cutting, unless you intend to drive in a straight line? Just my thoughts, i could be wrong though. Quote Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted December 21, 2003 Share Posted December 21, 2003 i just thought i'd read about someone with 27s and no lift. i want to at least fit some 25's then. i just need economical clearance. Quote Link to comment Share on other sites More sharing options...
Qman Posted December 21, 2003 Share Posted December 21, 2003 Yes, you did read about 27's without a lift. However he beat the hell out of his wheel wells so he could turn. He had to beat enough that he actually put a couple cracks in the rear of the front fenderwell. It took awhile but I managed to convince him that he needed a lift also. You can only beat these things so much. Quote Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted December 21, 2003 Share Posted December 21, 2003 i'm gonna go in the 25ish range. this will save me some money and i can always get a lift down the road. my current ride isn't the nicest so i'm not worried about beating the sh!t out of it. i'm sure when i purchase a nicer wagon my fire for a lift will be re-ignited. right now, i'm just struggling to make rent and pay my bills. i work 14 hour days 3-5 days per week and 7 hour days 6 days per week. i'm just trying to get re-established and stable once again. Quote Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted December 22, 2003 Share Posted December 22, 2003 tim, is it possible at all to fit the 205/75 r14's (26.1") under w/o a lift? Quote Link to comment Share on other sites More sharing options...
Rooinater Posted December 22, 2003 Share Posted December 22, 2003 yes 26" tires without a lift are possible. Zapar used them on his old, old white hatch. without a lift. Quote Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted December 22, 2003 Share Posted December 22, 2003 can't wait to try it. Quote Link to comment Share on other sites More sharing options...
Rooinater Posted December 22, 2003 Share Posted December 22, 2003 you'll need to cut the fender and bend the back of the wheelwell a little too. Quote Link to comment Share on other sites More sharing options...
