Plugging vaccum lines?
17 replies to this topic
#1 hardtail_pride
hardtail_pride
    Eat, Live, Breath Subaru
  • 280 posts
  • Orem
Posted 14 February 2008 - 01:18 AM
So i read here and there that people are plugging their vacuum lines and it helps their power? My wagon is just my beater so any extra power here and there would be awesome. I'm not sure if im mistaken or not though. What in particular should i plug? Thanks for any help and sorry for the vague question.:confused:
#2 one eye
one eye
    I'm A Subaholic
  • 2,503 posts
  • Mt.Vernon Washington
Posted 14 February 2008 - 01:29 AM
I plug off all my lines, I don't know if it gives you more power but It sure makes motor pulls and replacements a lot faster:grin: on my 83 wagon I think I have about 3 or 4 lines on it:rolleyes:
Jeff
#3 hardtail_pride
hardtail_pride
  • 280 posts
  • Orem
Posted 14 February 2008 - 01:36 AM
oh ok mine is a 92 loyale FI with quite a bit going on around the throttle body. Looks like a lotta emissions equipment but i wont be registering this beater again. Any suggestions or should i leave it alone?
#4 one eye
one eye
    I'm A Subaholic
  • 2,503 posts
Posted 14 February 2008 - 01:46 AM
I really don't know If that will mess w/ your car. It might mess with things and lean it out real bad, The mass air flow sensor could start to screw up. I worry about that thng, But it might not I'm not sure.
Jeff
#5 hardtail_pride
hardtail_pride
  • 280 posts
  • Orem
Posted 14 February 2008 - 01:48 AM
Alright i will leave it alone sounds like. Dang vacuum systems. I hate em!:mad:
#6 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,278 posts
  • Portland
Posted 14 February 2008 - 01:49 AM
Leave it be unless you know what it does. SPFI (any FI) is not to be trifled with till you understand it.
Once you understand it, you will no longer need to ask this question.
#7 hardtail_pride
hardtail_pride
  • 280 posts
  • Orem
Posted 14 February 2008 - 02:15 AM
haha so true thanks just exploring my resources.
#8 ivantruckman
ivantruckman
    4 inch lift
  • 858 posts
  • caro, MI.
Posted 14 February 2008 - 08:10 AM
study each vac line 1 by 1 and it wont seem so overwhelming, trace, plug verify,
#9 Stevethefolkie
Stevethefolkie
    USMB Regular
  • PipPipPip
  • 42 posts
  • Central Pennsylvania
Posted 14 February 2008 - 01:41 PM
or use a hemostat - trace - clamp off - verify - if no problem then pull & plug! (that way you never have to remember where a line went ....)
#10 Gloyale
Gloyale
    It's a sickness
  • 6,941 posts
  • Corvallis, OR PNW
Posted 14 February 2008 - 03:08 PM
Thi applies motly to Carbed models. And it isn't that the motor will make any more power. It is that old emmisions sytem develope leaks which cause poor idle, hesitation, and rich/lean mixture in some cases.
Eliminating a broken and hard to replace/service part eliminates the problem. And makes the engine run better. Not nessecarily with any more power. Just smoother and more driveable.
I myself make every effort to repair and maintain all my vaccum hoses and accesories. But sometimes it just isn't practical. I would not jut start ripping off vac lines to gain power. Won't happen.
Besides, with FI, there really aren't many *extranious* vac lines. It pretty much all need to be there. Leave it alone and do a tune-up*. Much better way to make it run nice.
*Complete Loyale tune-up:
plugs
wires
cap
rotor
fuel filter
airfilter
pcv valve
Replacing all Vac hoses is a good idea too
#11 MilesFox
MilesFox
    Catch this Fox!
  • 9,123 posts
  • Madison/Milwaukee, WI
Posted 14 February 2008 - 03:17 PM
all the vac lins can be removed, if you have the intake off the whole metal vac line system is removeable as one piece, and you would connect the cabin vacuum from the firewall to the nipple on the intake itself.
although i dont recommend this unless something is broken or you are building legos.
i stripped my sedan's spfi and it could stand to run better.
anf anything you eliminate it could be the egr or purge control, but only if those systems dont work anywy.
althoug it looks like a rat's nest, the spfi vac system is rather simple
#12 GeneralDisorder
GeneralDisorder
  • 20,278 posts
  • Portland
Posted 14 February 2008 - 08:12 PM
That simply is not true. The fuel pressure regulator vac line cannot be removed and still have the SPFI run correctly.
Besides - he shouldn't be attempting this till he understands what each of these devices does, and what he is potentially losing should he remove them. There are pro's and con's to each.
Also you aren't going to get a single ounce of extra performance for your trouble. So unless you just like things to look clean, you shouldn't touch it.
#13 Ice Racer
Ice Racer
    New User
  • Pip
  • 9 posts
  • TOronto, Ontario
Posted 15 February 2008 - 03:07 PM
Hi all, first post! :clap:
Last March '07 I bought what was originally an '83 GL 4WD 4-speed but over the years has turned into a Frankenstein of parts. I bought it from a former ice racer and I use it exactly for that...Ice Racing!
Anyways, I'm watching this thread with interest as I'd love to make the ol' EA81 engine a little more reliable.
You all seem to know your stuff so I hope I can learn a little something here and there.
Here are some pics: :headbang:
Posted Image
Posted Image
Posted Image
Thanks!
#14 suburpy
suburpy
    Soob Goob
  • PipPipPip
  • 101 posts
  • Adelaide
Posted 15 February 2008 - 03:12 PM
Its just my opinion but the ea81 is a really f***n reliable engine - ************ it is used regularly for light aviation duties. But that's irrelevant - Ice Racing !!!! Sick Man - love to have a black and gold trim ea81 turbo for that :Flame:
#15 hardtail_pride
hardtail_pride
  • 280 posts
  • Orem
Posted 15 February 2008 - 11:30 PM
HAHA that subaru is Fin sick! Nice dude
#16 Ice Racer
Ice Racer
    New User
  • Pip
  • 9 posts
  • TOronto, Ontario
Posted 21 February 2008 - 11:40 AM
Yeah, figured you guys would get a kick out of it. If you do a search for Suzie Subie Racer on YouTube you'll find all my videos. From when I bought it, fixed it up, and raced it.
Or you can click here: Suzie the Subie :banana:
#17 glkiller
glkiller
    New User
  • PipPip
  • 19 posts
  • Lapine
Posted 21 February 2008 - 03:24 PM
now that's a cool car!
I found somewhere in here a pic a guy took of his ea81 that had all lines plugged and I run that way now too.
Like mentioned before though, it won't give you more power just eliminate any vacuum leaks from your 25 year old emission system.
On a newer fuel injected system there is almost nothing that you should plug off, even the egr, leave it alone if you want it to last.
BUT on the ea81 THE ONLY LINES YOU REALLY NEED ARE THE FOLLOWING
Cabin vacuum- for the heater controls, long vac line out of the firewall, can't miss it.
PCV Valve- anyone who tells you you don't need this is a blubbering boob.
Brake vacuum hose- brakes are no fun to use without SOME help
Distributor vacuum advance- tells your ignition timing to advance when engine is under a load = more power. I connect this to above throttle port vacuum left side tube, bypassing the thermo vacuum switch wich switches the vacuum from manifold when cold to above throttle when warm (just another connection and part that can and does go bad.
I've been running like this for awhile now, doin great.
TAKE SPECIAL CARE IF PLUGGING EGR THAT YOU GET IT TOTALLY PLUGGED
and be aware that by design the egr system is supposed to cool your valves and reduce emmisions
old cars carbed, plug away
FI- don't be ridiculous Balky......
#18 glkiller
glkiller
    New User
  • PipPip
  • 19 posts
  • Lapine
Posted 21 February 2008 - 04:33 PM
OH HEEEEY 1 more thing...
Your secondary throttle on an ea81 hitachi carb is activated by vacuum, if you have a major leak it won't work turning your car into a 1 barrel.
I say this mostly for iceracer. plug all the stuff and check this out, I've done it and it works great! At first I had a problem with it sticking open but a small adjustment to the .02$ wire fixed that. (it would flood and be hard to start)
But if in question check out this thread:
http://www.ultimates...light=secondary
If you remove the secondary diaphram like I did be sure to seal the hole or you'll make a vac leak.
