Rear wheel bearings
4 replies to this topic
#1 aircraft engineer
aircraft engineer
    Subaru Nut
  • 518 posts
  • close to Tacoma
Posted 16 February 2008 - 10:05 PM
working on 97 Impreza WGN - drum brakes - OK - I bought a wheel housing at a yard - 98 Forester, Good bearing, (pax side) pressed out hub, pressed off outside race, disassembled Impreza, swapped backing plates. When I put the hub in, it seems "tight" right now. It didn't seem to press in any farther than the forester was. What's the worst that can happen - burn up the bearing? It was well greased
How much interference was designed into these? Anybody know?
Up on the jack stands - Separate manual turning pax rear turns driver side, but turning driver side doesn't turn pax wheel. I bought a new bearing if I need it so I have it
Still don't know if the bearing noise will still be there (might be worse with it this tight).
#2 ericem
ericem
    First Gen Legacy Master
  • 2,477 posts
  • CANADA Maple,ON
Posted 16 February 2008 - 10:26 PM
I thought the forester had different sized bearings??
#3 four-fleet-feet
four-fleet-feet
    USMB is life!
  • 209 posts
  • Seattle
Posted 16 February 2008 - 10:55 PM
No, same size, we checked that first.
Note: these aren't the 'new' roller bearings, but the original OEM ball bearings.
#4 tcspeer
tcspeer
    1000+ Super USER!
  • 1,444 posts
  • Walnut Springs
Posted 17 February 2008 - 10:25 AM
You may have the hub pressed in to tight, If you can turn it by hand it may be O.K. I replaced one with a new bearing and it was a little tight but it would turn by hand so I put it on and had no problems with it.
Push the hub back just a bit and see if it free's it.
#5 aircraft engineer
aircraft engineer
    Subaru Nut
  • 518 posts
  • close to Tacoma
Posted 18 February 2008 - 08:06 AM
drove it a few miles and it loosened up to the same as the driver's side (it wasn't that "tight" to start with)
The NOISE IS GONE!!
Support the inner race on the inside of the housing and press the hub in while supporting the inner race. Apparently the trick is to push the hub to within about 1/4 inch of the housing, put in the axle outer seal then install the housing and pull the unit the rest of the way in with the axle nut (seemed to work anyway) since the depth of the bearing is fixed by the shoulder plus the snap ring and the problem was with the inner races. (I had the entire housing/hub unit off the car because I had to swap the backing plate and hub into the junkyard replacement housing)
