New clutch does not functino
EA-81 here:
I replaced my clutch with my engine swap last spring. It always had a bad shudder so I finally got around to trading it in under warantee at schmucks. Also picked up a refurbed flywheel. Popped all of the above in and now it slips bad. I even adjusted my linkage to the point where I have about 2 inches of freeplay before I start to feel resistance. As soon as I even touch that resistance, it is basically disengaged. I am thinking I got a bum pressure plate. Any ideas?
-- Jeff
you should also try the clutch cable. I was having some similar issues and it was really pissing me off, finally the cable broke and i had to replace. it was like getting a totally different car. 23.00 and 20 minutes is easier than pullin everything again. It took me two complete kits and 5 times of pullin to get it right. thank God it only takes 25 minutes to pull
