Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
6inch lift kit home build
#1
Posted 23 February 2008 - 11:44 AM
day one
http://s247.photobuc...t=strutower.jpg
http://s247.photobuc...6inchblocks.jpg
http://s247.photobuc...nt=liftkit1.jpg
#2
Posted 24 February 2008 - 05:13 AM
You going to reinforce those 2x3x2" pieces? Don't want them just folding over.
#3
Posted 24 February 2008 - 06:24 AM
I didn't mind building it and would do it again.
Of course it helps when a neighbor drops by and asks: "where did you buy that lift kit, I didn't know you could buy one for those cars?"
#4
Posted 24 February 2008 - 01:36 PM
#5
Posted 24 February 2008 - 09:21 PM
http://s247.photobuc...lockinstall.jpg
#6
Posted 12 March 2008 - 02:21 PM
why extend the struts up? where they sit stock is likely the best place for them, your not going to be rubbing your tires on the spring...? no angles, just add the extension to the bottom.. maybe im wrong here but sometimes simple is better.
[quote name='ivantruckman']hey scott ..the pipes are 4 1/4 od .125 wall i cut the flanges with a plasma cutter, i cut out a template out of wood , and use a drag sheild. still a lot of work to do. and steel prices have gone up big time, i used drop peices at the local steel shop, but i still have about 100 bucks in small peices of steel..
#7
Posted 12 March 2008 - 04:16 PM
#8
Posted 12 March 2008 - 04:41 PM
This is what I did. I took a new strut, cleaned off the brackets, cut an old strut bottom (with brackets) 7" in length, measured the length, looked high, and low, for a piece of tubing to sleeve the assembly in a shrink fit situation (freeze strut, and bottom piece, heat tubing) quickly assemble, weld tubing to spring mount on the top, and the bottom piece.
End result: bad camber
Remove lower control arms, and lengthen by an inch, plating the bottom for extra strength, slot upper strut mount holes, and now the camber is under control AND fully adjustable.
Looking back at it I should have just made the offset top mounts, but I know that my stresses created by driving is in line with what it was originally, and not offset.
#9
Posted 16 April 2008 - 06:48 PM
http://s247.photobuc...ent=2subies.jpg
http://s247.photobuc...rrent=front.jpg
how do you get these stupid pics to show up instead of posting a a link arrggggg
#10
Posted 16 April 2008 - 08:39 PM
updated pics
There is a little icon for inserting a picture, it looks like a little mountain and sun or some such.
#11
Posted 16 April 2008 - 08:40 PM
updated pics
There is a little icon for inserting a picture. You need to use the "direct link" one, not the "email IM" one that you used.
#12
Posted 26 April 2008 - 12:54 AM
As for the strut extension, a lower extension is the way to go. I started with an upper, but the tires would rub all the time. I've been running my 7" lowers for about 4 years now, holding up strong. They are made from 1/4" wall that I pressed onto the strut. I did have a little trouble with the knuckle falling off the strut at full extension, so I added the tab. (if I had knuckles in better condition, it wouldn't have been a prob, but mine are pretty abused.)
#13
Posted 28 April 2008 - 11:05 AM
Kewl work. There definatly is a sense of pride when you do something like this yourself. Keep up the work.
Only problem with the strut bottom extension is the camber.
If you just effectively lengthen the shock, you are pushing the top of the knuckle outward. end up like this \-/
With strut tops, you can make them with an angle to compensate, and actually improve over stock camber.
